EAGLE User Support (English) Example of complete polygon command
  • Subscribers 177 subscribers
  • Views 1821 views
I think that working with polygons in a script is never used.
Therefore I will repeat the question how to produce a polygon in a script
again here in this forum.
In the help file there is a explanation of the polygon syntax as:
POLYGON . curve . ...
But there is no actual example.
I need a polygon that goes from (-50 0) to 'half circle' (0 50) to
'straight' (0 36) to 'half circle' (-36 0) and back to (-50 0) to complete
the polygon.
The reason for a script is that I have to repeat the script for several
designs that may have small differences in dimensions that are easier done
in a script than on a board drawing.
Harry
    What makes you think so?
    the polygon.
    Just follow exactly the given help there (and in the help for WIRE,
    where the curve/radius parameters are explained - including example!):
    poly .3 (0 -50) @-50 (0 50) (0 36) @+36 (0 -36) (0 -50);
    (Assuming that you really meant the half circle, opposed to the
    coordinates given above.)
    Tilmann
    "Tilmann Reh" <user@domain.invalid> schreef in bericht
    news:gvgm2n$nh1$1@cheetah.cadsoft.de...
    No example to be found on the Web
    complete
    the polygon.
    Never found that, sorry
    Created the following lines to make a complete circle
    1. Mark components placement area for mechanical clearance
    Change Layer tNames;
    Change Pour Hatch;
    Poly .2 (0 -50) @-50 (0 50) (0 31.7) @+31.7 (0 -31.7) (0 -50);
    Poly .2 (0 -50) @+50 (0 50) (0 31.7) @-31.7 (0 -31.7) (0 -50);
    Tilmann
    Harry
