EAGLE User Support (English) Bug in ULP strtol?
  • Subscribers 177 subscribers
  • Views 342 views
Bug in ULP strtol?
ULP -      output("c:
eagle_debug.txt", "wt") {
          printf("Starting a run of ULP %s - ", argv[0]);
          int t = time();
          printf("It is now %02d:%02d:%02d\n",
          t2hour(t), t2minute(t), t2second(t));
     int n = 16;
     for (int i = 0; i <= n; i++) {
     string outputs;
     int outputu;
     sprintf(outputs,"%2.2u",i);
                output("c:
eagle_debug.txt", "at") {
                           printf("i as string = %s - ", outputs);
                           outputu = strtol(outputs);
                           printf("i as strtol = %u\n", outputu);
                           printf("\n");
Output
Starting a run of ULP C:/Program
Files/EAGLE-UserFiles/ulp/test_strtol.ulp - It is now 09:26:16
i as string = 00 - i as strtol = 0
i as string = 01 - i as strtol = 1
i as string = 02 - i as strtol = 2
i as string = 03 - i as strtol = 3
i as string = 04 - i as strtol = 4
i as string = 05 - i as strtol = 5
i as string = 06 - i as strtol = 6
i as string = 07 - i as strtol = 7
i as string = 08 - i as strtol = 0
i as string = 09 - i as strtol = 0
i as string = 10 - i as strtol = 10
i as string = 11 - i as strtol = 11
i as string = 12 - i as strtol = 12
i as string = 13 - i as strtol = 13
i as string = 14 - i as strtol = 14
i as string = 15 - i as strtol = 15
i as string = 16 - i as strtol = 16
Glenn
    Glenn Jones wrote:
    Forgot to mention this is in 5.6.0
    This is not a bug. Numbers with leading zeros are interpreted as octal
    numbers and 08 and 09 are not valid octal numbers. Since strtol is not
    able to convert the string to a number it returns 0.
    Search the help for 'strtol()' and 'integer constants' for details.
    To avoid leading zeros in the output and have the numbers padded with
    spaces you could use
       sprintf(outputs,"% 2u",i);
    instead. The added space acts as padding character. I stripped the .2
    from the format specifier because the precision specifier only makes
    sense for real numbers.
    Christoph
    autodeskguest over 16 years ago in reply to autodeskguest
    Christoph Wurzinger wrote:
    Christoph
    Hi Christoph,
    I was parsing input that has leading zero's and converting to integer so
    I could increase the value by one and make a string out of it again.
    So I will strip off leading zeros, increment and then print back to a
    zero leading string. The leading zero is not really required but i would
    rather not modify the data as supplied more then necessary.
    And you are correct what I wanted was sprintf(outputs,"%02u",i);
    Thanks for the explanation.
    Glenn
