EAGLE User Support (English) Differing via sizes
  • Subscribers 179 subscribers
  • Views 1014 views
Differing via sizes
oldevel
oldevel over 10 years ago
Hi, I am starting a 4 layer PCB using v6.5.0 pro, and have added the following layers setup : ([15:(1*2)*(15*16):2])
Under Sizes, minimum width, drill, and micro via are 0.25mm with ratio 0.5.
Under Restring, via min and max are 0.2mm.
With width 0.3, diameter auto, and drill 0.25, when I route on layer 1, and switch to layer 2, the resulting via has outer and inner diameter of 0.4532mm.
When I route on layer 1, and switch to layer 15, the resulting via has outer and inner diameter of 0.6564mm.
This is unexpected behavior, and neither searching on Google or attempting different DRC settings has led me anywhere.
I will be grateful for any assistance towards understanding this behavior.
Thank you
  • xeptio
    xeptio over 10 years ago +1 suggested
    hello ol devel, maybe the reason is because you have choice different parameter for via and micro via try to put the parameter you put for the via in the case for micro via below the via case MD
  • xeptio
    0 xeptio over 10 years ago
    hello ol devel,
    MD
  • oldevel
    0 oldevel over 10 years ago in reply to xeptio
    I contacted Cadsoft and they were able to assist. I needed to set Min and % Vias Restring to 0 in order to gain control of Restring diameters. Thank you for your answer.
