EAGLE User Support (English) Add new properties to CHANGE function
  • Subscribers 179 subscribers
  • Views 312 views
kikoun
kikoun over 10 years ago
It would be nice to have  more properties accessible by the CHANGE functions :
-for PAD,PART, TEXT, ARC,circle, Holes etc... :       CHANGE HOR-POS , CHANGE VERT-POS,for changing the horizontal and vertical position
-for ARC, Circle:                                                        CHANGE RADIUS,
-for RECTANGLE :                                                      CHANGE UPPER, CHANGE LOWER, CHANGE RIGHT, CHANGE LEFT, for changing the Upper, lower, right and left position.
This would be great, because we could easily apply a change to a group:
- place all part/pad on a same vertical (horizontal) position.....
Guillaume.
  • clem57
    0 clem57 over 10 years ago
    See other comment about snap to grid...
  • kikoun
    0 kikoun over 10 years ago in reply to clem57
    thanks but it not what I need because the grid is not enough (see my other post on the '.' bug. ) The grid is too limited. Maybe your right in a way that maybe it's not the change function that need enhancement, but rather the grid options :
    - possibility to use a different origin
    - a way to define 2 different pitch (one for each direction)
    - or a way to snap to the grid but only in one direction.
    Guillaume
