EAGLE User Support (English) Scaled outputted texts
  • Subscribers 179 subscribers
  • Views 591 views
Hi. Can someone please help. Why are the texts on any physical layer always scaled up when i output them in the cam processor? And what can i do to avoid this again? Thanking you in advance. Regards Bruce.
  • clem57
    0 clem57 over 10 years ago
    Oh this has too many answers, but it depends on doing a SMASH to allow adjusting text. A good how to is http://makezine.com/projects/make-36-boards/make-your-own-dmn-board-part-3-silkscreen-and-gerbers/
    Take a deep breath,
    Clem
    0 Former Member over 10 years ago in reply to clem57
    Hi Clem
    Thank you so much. Going to give it a try now. Hope it works. Take care.
    maybe a problem with proportional fonts in the layout vs. vector font
    in the geber output?
    Lorenz
    Hi
    Your problem is likely caused because you have not used vector fonts and
    used the better looking proportional fonts. You need to use vector fonts on
    the board. This often comes up in the forum and is documented in the
    manual.
    Quoting the manual
    The option Always vector font shows and prints texts with the builtin
    vector
    font, independently from the originally used font. Using the Vector font
    guarantees that the output with a printer or the CAM Processor is exactly
    the
    same as shown in the editor window. Fonts other than vector font depend on
    the systems' settings and cannot be controlled by EAGLE. The output of
    nonvector
    fonts may differ from the editor's view.
    ENd quote
    You can also use proportional in the schematic and vector for the board
    HTH
    Warren
    0 Former Member over 10 years ago in reply to autodeskguest
    Hi lorenzo
    Thank you for your help.I did try both options & still didnt work. Thank you again.
    Hi Warren
    I am going to start from scratch again with a layout using your suggestion. i hope it works. Thank you very much for your assistance.
