EAGLE User Support (English) Can you MOVE using arrow keys?
  • Subscribers 187 subscribers
  • Views 1232 views
Is there any way to make fine adjustments in positioning or an element while
in the Move command using the keyboard arrow keys?
I have this function on another CAD package and found that it is useful when
trying to make small orthogonal adjustments. On that, once in the move
command, you can control either from mouse or by arrow keys.
As long as I mention the other CAD... it uses the home key to center the
window on the current cursor position.
Is there any way in Eagle to ASSIGN to keys other than the ones in the
pull-down menu (Assign - new)? I would like to map the HOME key (as eagle
does not seem to use it otherwise?) to be 'Window (@);'
    I don't know of a built-in way to move with arrow keys. I looked in the
    ULP reference for a variable that would define the current position of the
    cursor. I didn't find that reference. However, I suspect a package on a
    board would have an x,y location of its center available via ULP.
    One approach you could use is to use MOVE and specify the exact
    destination via a keyboard entry. Check the documentation for relative
    coordinate syntax. You can move relative to the current position by
    whatever unit you want.
    Finally, you have probably noticed that ASSIGN only likes F1..F12 , BS,
    numbers and A..Z which I agree is frustrating.--
