EAGLE User Support (English) 7583222  ALUPLUS TOOLCASE 18
  • Subscribers 179 subscribers
  • Views 336 views
i need some info about AluplusTool case 18, Farnell no. 7583222; maybe you could tell me if it is possible to take out the sections? I need it to be able to make absolutely empty, is it possible?
Thank you!
Sincerely,
Lina Kundrotaite
"Lemona"
  • gadget.iom
    0 gadget.iom over 10 years ago
    The partitioning is removable, It just slides into the slots in the case walls and any joining partition panels.
    According to the data sheet, the tool-plate is also removable.
    I have purchased similar cases and removed all of the internal components and side-wall slots in order to install a custom switch panel.
  • gadget.iom
    You might also want to look at something like this:
    PULSE - ACC-CASE-M - FLIGHTCASE, UNIVERSAL, MEDIUM | Premier Farnell CPC UK
    The foam inserts can be removed, giving you an empty case, and the cost could work out to be significantly lower.
