EAGLE User Support (English) BeagleBone black
  • Subscribers 187 subscribers
  • Views 787 views
BeagleBone black
2 weeks ago - I obtained BeagleBone black. I uninstalled completelly the following services:
cloud9.service
gateone.service
bonescript.service
bonescript.socket
bonescript-autorun.service
avahi-daemon.service
gdm.service
mpd.service
Following commands works well:
echo 39 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio39/direction
echo 1 > /sys/class/gpio/gpio39/value
But the GPIO ports flashes with frequency approximatelly 2 HZ. I cannot stop that. The timers aren't initialized. Additionally - I tested with external MMC card and Amstrong image. The situation is the same. I suppose - the processor has hardware defect.
Can you advice me - how to proceed?
Best regards:
Darin Masov
    0 shabaz over 11 years ago in reply to e14 Contributor
    I don't think discussions should be deleted unnecessarily - the information could help someone else if not you - I took effort creating my reply.
    Better to move the discussion to another location however.
    0 e14 Contributor over 11 years ago in reply to shabaz
    "You have not shown your code or script that caused 2Hz"
    That is the problem - I did not initialize any script to blink at 2 HZ. GPIO do not need to blink.
    Now I will try try to find the correct thread.
    p.s. I will be thankful if someone delete the discussion.
    Hi Darin,
    Your question is in the wrong thread (EAGLE is not related to Beaglebone). Anyway, you should be getting higher speed but it still doesn't sound like a hardware defect. You have not shown your code or script that caused 2Hz
    flash rate so it is hard to help further.
    Anyway, the BBB GPIO method described here allows for around 2MHz rate.
