EAGLE User Support (English) Plane ground bottom pads
  • Replies 11 replies
  • Subscribers 178 subscribers
  • Views 1171 views
When i build my plane ground on my bottom face. There is no plane ground around the pads of my components even if the components are in the top face. I search to solve this problem.
Thank you.
    You question is not very clear to me! Do you mean that you've placed a
    Polygon on the bottom layer of your circuit board, and used the 'Name'
    function to define this polygon as GND? Also, are you talking about
    thru-hole components or SMT components?
    This may be a case were we actually need to see what you are talking about
    to help!
    0 Former Member over 10 years ago in reply to autodeskguest
    Hi
    Yes it's exactely what i did. It concened all the components. I only use SMD components. The area around the pads is not in ground
    0 autodeskguest over 10 years ago in reply to Former Member
    I still don't have a completely clear picture of your situation. Are these
    SMT components on the Top layer or the Bottom layer? If on the Top, I would
    generally expect the GND fill under the SMT components on the Top layer. If
    on the Bottom, I would expect the GND fill to be around the non-GND pads
    with a suitable clearance 'relief', and for GND pads I would expect that
    they would be connected to the GND plane. The only exception I can think
    of, where GND connections would still be connected with 'air wires', would
    be if somehow the GND polygon was not continuous. You'd only see this for
    components on the Bottom layer.
    My components are on the top layer. I will send you a picture it will be more clear maybe. On the picture you can see that i have areas where there is no plane ground. Theses areas are where i have my pads but in the top layer.
    On the bottom layer, i have few routes and the ground. Do you understand more ?
    Thank you in adance.
    0 Former Member over 10 years ago in reply to Former Member
    I have two planes ground (bottom and top layer).
    Thank you.
    Where did the SMT part definition come from? Did you find it in a specific
    library, or did you create it? If you found it in a library, which one, and
    what is the part name?
    The only thing I can think of is that you have some sort of a 'Keepout' or
    'Restriction' on the bottom layer (bKeepout or BRestriction layers) defined
    for the part(s). I've never used it, but ordinarily I believe this is to
    prevent copper from being placed underneath certain components (crystals,
    etc.) for impedance control purposes. Can you look at the layer definition
    for the part(s) that are the problem?
    I created my own library. How can i check the definition of a layer ?
    If you created your parts from scratch then it's probably not the issue,
    but if you started with an existing part then it might be. Look at the
    'Package' view in the library, and see if anything, typically a
    cross-hatched box, surrounds your pads. Use the 'Info' tool to check the
    layer definition for everything on/around the pads.
    I try to see if it's the name with a library of Eagle and i have the same results. I use library 40 xx with a DIL8.
    Thank you.
    I think my problem is because i put my components like SMT in the "reality" but with the software understand that i put them like through hole. I think i have to change the pads of my own library in SMT pads ? But how can i have the same forms of pads ? I have no choice in Eagle ?
    Thank you.
