EAGLE User Support (English) Can you add thermal area to a package?
  • Subscribers 180 subscribers
  • Views 496 views
alank2
alank2 over 10 years ago
Let's say you have a sot223 with 4 pads and you want to add some more copper to pad 4 to allow it to cool better.  How can this be done on the package?  It does not like it when I add a wide trace to it on the top copper layer (drc errors).
  • e14candies
    0 e14candies over 10 years ago
    You can add copper to the top layer at your pad, just make sure to name the
    copper using the same net the particular pad uses.  This is referring to
    the actual board layout, not your library (there may be a way to do that as
    well).
  • alank2
    0 alank2 over 10 years ago in reply to e14candies
    I was hoping for a way to make the changes in the library, but I don't see a way to name traces the same as the pin in the device editor...  Any other thoughts on how to do this?
    See the manual
    8.14 Arbitrary Pad Shapes
    HTH
    Warren
  • alank2
    0 alank2 over 10 years ago in reply to autodeskguest
    Thanks Warren, I did try this and it worked.  Does it only work with polygon's?  I don't think it worked with a trace when I tried that.
    0 autodeskguest over 10 years ago in reply to alank2
    http://www.element14.com/community/message/154170
    It works with WIRE in a package
    See HELP>Editor Commands>PAD> Arbitrary Pads Shapes
    HTH
    Warren
