EAGLE User Support (English) How do I do a Solder Mask Defined Pad with Eagle?
  • Subscribers 187 subscribers
  • Views 1237 views
I have been learning and evaluating Eagle for our company. I like what I
see so far but I cannot figure out how to do a Solder Mask Defined Pad. As
an example of some devices that use them
In Figure 1 here
http://www.irf.com/technical-info/appnotes/an-1028.pdf
http://www.eetasia.com/STATIC/PDF/200906/EEOL_2009JUN16_EDA_AN_01.pdf
Page 13
http://www.freescale.com/files/32bit/doc/package_info/PBGAPRES.pdf
In some cases we have projects that are required to withstand high G
forces. We would like to keep the option of doing a Solder Masked Defined
Pad open for just such a case.
Unfortunately we cannot directly define a solder mask pattern that is
smaller than the pad in the footprint editor. Also if we could the
automatic soldermask generation in the preferences would overwrite it.
Does someone have a work around other than manually editing the gerbers? I
would hate to have to do this on a 300+ ball BGA.
Thank You
Conn Clark
Observation: In formal computer science advances are made by standing on
the shoulders of giants. Linux has proved that if there are enough of you,
you can advance just as far by stepping on each others toes.
    ConnClark wrote on Mon, 29 June 2009 12:11
    In Figure 1 here
    AN_01.pdf
    Page 13
      http://www.freescale.com/files/32bit/doc/package_info/PBGAPR ES.pdf
    I would hate to have to do this on a 300+ ball BGA.
    Thank You
    Conn Clark
    Hello Conn,
    You can do this in EAGLE easily.  In the package editor turn off "STOP"
    for the smd(s) in question.  You can do it with the info properties box for
    individual pads.  But if you have a lot then group them all and use the
    change command to apply to the whole group.  Syntax is something like
    CHANGE STOP OFF
    but see the help for the change syntax, this is off the top of my head and
    could be wrong.
    Then define the mask opening you want on the appropriate t/bStop layer.
    If you set your grid correctly then you can copy it easily to the new
    location to get a row, then group, cut, and paste rows to fill out the
    rest.
    That's it.  You then need to update from the design if you already have a
    design with the old package included.
    Cheers,
    James.
    email:  sales2009@eaglecentral.ca
    fax:    888.701.8097
    web:    http://www.eaglecentral.ca
    Online EAGLE Dealer for US and Canada
    EAGLE Design Experts
    EAGLE Enterprise Toolkit
