EAGLE User Support (English) Deleted part name - How to recover it?
  • Subscribers 178 subscribers
  • Views 813 views
Former Member over 16 years ago
Hi, I have Eagle 4.16 and after I smashed a component, in the schematic, I
accidentally deleted the part name.  How can I recover the name of the part
to show it again on the schematic?
thank you,
Guy
    Guy Desbiens wrote on Fri, 03 July 2009 14:12
    I
    part
    Hello Guy,
    To do this you need to "unsmash" the part.  You hold down one of the
    modifier keys (shift I think, but check "help smash" for more info) while
    smashing to unsmash.  This will undo any smashing and or deleting of >NAME
    and >VALUE.  You can then smash again and move things around.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specialising in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    thank you,
    Guy
    Why not hit the F9-Key (undo)?
    Gruß / regards
    Jörn
    autodeskguest over 16 years ago in reply to autodeskguest
    Greetings power users,
    As I was reading this post and looking at the Help|Smash information in
    Eagle, I thought to myself, "How would I program the Shift+Left mouse click
    in a Script?"
    I recalled reading about this somewhere, and since I learn so much from
    reading these forum posts, I thought I would offer what I found.
    In the Eagle User Manual (page 89 for version 5.0) there is a discussion
    about Right Mouse Click. Quoting from the manual, "The > character within
    parenthesis represents a right mouse click. That way one can move a whole
    group, for example:
    MOVE (> 0 0) (10 0);
    ..moves the group 10 units in the x direction."
    Following this is the Modifier: section where "S" represents the Shift
    key.
    This raises the question however, will the modifiers work if coordinates
    are not part of the command? My experimentation says NO. I tried:
    "SMASH J1" followed by a Shift-LeftClick of the mouse. The part unsmashed
    (moved labels returned to default positions).
    I tried "SMASH J1 (S);" and received the error "Invalid point: (S);"
    I tried "SMASH J1 (S0 0);" with no positive or negative results.
    "SMASH J1 (S@);" works IF the cursor is positioned over J1. If positioned
    elsewhere, the command ignores the J1 reference and unsmashes the part
    under the cursor.
    So, power users, comments...?
    Jeff Rockel
    WI, USA
