EAGLE User Support (English) Copy between schematic sheets
  • Subscribers 177 subscribers
  • Views 3808 views
Is it possible to copy and paste existing schematic sections between sheets
or separate design files altogether?
For example if I want to create a new sheet #2 and duplicate something from
sheet 1, I can't seem to do it.  Same with opening up an older schematic.
I'd much rather copy and paste a schematic block into the new design than
have to manually add and wire up everything from scratch.  There has to be a
way.
    I figured it out.
    I was getting thrown off by the fact that when I'd start a group copy, the
    items would stick to the cursor showing it's being copied but then when I'd
    switch to another schematic sheet the items would vanish so I thought the
    process was terminated.
    "Jason" <jason.penney@mmbresearch.com> wrote in message
    news:h3naof$j1a$1@cheetah.cadsoft.de...
    sheets or separate design files altogether?
    from sheet 1, I can't seem to do it.  Same with opening up an older
    schematic. I'd much rather copy and paste a schematic block into the new
    design than have to manually add and wire up everything from scratch.
    There has to be a way.
    I just tried the following in ver. 5.6.0 and it worked:
    1) Group - select the parts you want to copy.
    2) Cut - click on a reference point that will be used for paste.
    3) Click on the sheet you want to paste to. Or right click and create a
    new sheet. (Use the "Sheets" toolbar.)
    4) Paste - click where you want to place the parts.
    When going from project to project, you must open the new schematic sheet
    in the same Eagle editor. So...
    1) Group
    2) Cut
    3) File | Open - schematic to paste to.
    4) Paste
    Hope it works for you.
    Jeff Rockel
    WI, USA
