EAGLE User Support (English) xconvert?
  • Subscribers 184 subscribers
  • Views 624 views
xconvert?
jwest
jwest over 16 years ago
Found on the web a reference to xconvert - says it ships with Eagle and can convert OrCad netlist format (multiwire) - so, where is that?
I see the utils in the users area - most of those are > 9 yrs old - are you guys serious about us using that (with confidence)?
If I can't import OrCad netlists successfully - it's a deal killer for me.  Good thing the 30-day money back guarantee is there.
Thanks And Regards,
=  Posted using GrabIt  =----
=  Binary Usenet downloading made easy =----
-=  Get GrabIt for free from http://www.shemes.com/  =-
  • Richard_H
    Richard_H over 16 years ago
    John Westmoreland schrieb:
    Thanks And Regards,
    xconvert was developed in the late 80s and came with EAGLE 2 and 3.
    It no longer part of the EAGLE distribution.
    There are available some newer user contributed tools in the
    Downlaod area. Please check for example importbom_and_netlist.zip
    in the ULP directory.
    HTH
    Richard Hammerl
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:h4u67e$gq6$1@cheetah.cadsoft.de...
    Thanks And Regards,
    HTH
    I have it in 4.16, right in the bin directory.
    Export from Orcad a 'Multiwire' Netlist.  Then you can run xconvert to
    create a script, which creates the netlist in a board.
    You must have all parts laid on the board to connect.
    Unfortunately you can not import a netlist to a schematic.
    Cheers
  • jwest
    Hello Martin,
    Can you please e-mail that to me?
    Thanks!
    "Martin Eder" <martine001@verizon.net> wrote in message
    news:h52nf4$s9p$1@cheetah.cadsoft.de...
    Thanks And Regards,
    HTH
    Cheers
