EAGLE User Support (English) Cross Hatch Fill
  • Subscribers 177 subscribers
  • Views 349 views
Cross Hatch Fill
I am in the process of completing a new design that will use a hatched ground plane on the top of the PCB to protect cap touch traces on the back of the board.  The issue that I am running into is direction of the hatch.  All of the hatch traces run north and south on the board and I need them to run at 45 degrees, or cross hatch style.  How can this be done?
Stephen
    AFAIK, the direction is fixed.
    You could complete your design, then make a 45° rotated copy of your
    board, and generate the CAM data from that. Might be interesting for
    your board house, though... image But I think they can deal with that.
    Tilmann
