EAGLE User Support (English) autoplace
  • Subscribers 183 subscribers
  • Views 1297 views
autoplace
Former Member over 15 years ago
Is there a solution for auto placing the components?
I've found autoplace_v3.ulp in this webpage:
http://www.cadsoft.de/cgi-bin/download.pl?page=/home/cadsoft/html_public/download.htm.en&dir=eagle/userfiles/ulp
this autoplace places the components in the layout based on the schematics,
but I didn't manage to make it work. I did as follows:
- I did my schematic
- I clicked on "board"
  (a new layout appears, with all the components placed by default)
- From the "Board" window, I select Menu->File->Run: autoplace_v3.ulp
The software says: "Run: autoplace_v3.ulp: finished",
but I don't see any change in the layout; no component have been moved.
I've tried several things without luck (such as putting everything in the
first quadran). currently there board size limitation should not be the
problem, the schematic is quite small.
How to make autoplace_v3.ulp work?
Also, is there any other solution for autoplace?
Best regards,
David
