EAGLE User Support (English) Dimension in script file
  • Subscribers 186 subscribers
  • Views 799 views
  • eagle
  • dimension
  • script
jltharin
jltharin over 12 years ago
Hi everybody!
I have a problem with dimension in eagle 6.5
When I write in the command line a dimension for example: "dimension vertical (-10 10) (-10 90) (-20 50);", it works my dimension is put like in parenthesis (the value of dimension is 80)
But now my goal is use a script to do this because I have a lot of dimensions to put and they are very often the same.
So I copy the command line in my script file
And the result is 90 like if it doesn't care about the first parenthesis.
Is it a bug of Eagle or did I do an error somewhere?
Jean-Louis
  • jltharin
    0 jltharin over 12 years ago
    Found the problem:
    For people that have the same problem is in the script file we need to add a "C" before the first coordinate, like this:
    dimension vertical (C-10 10) (-10 90) (-20 50);
