EAGLE User Support (English) Part Dimensions on Data Sheet?
  • Subscribers 178 subscribers
  • Views 315 views
sailmike1
sailmike1 over 11 years ago
I'm making a custom part for the Cree MX3S high power LED's. The attached picture shows the dimensions of the pads and heat sink die. I used the hole tool to add the thermal vias and made them 0.2mm in diameter even though the data sheet doesn't mention the diameter of these holes. On the data sheet for the part dimensions I see these lines marked in the photo with red arrows. I didn't know what they were for so I just used them to show the part on the PCB (the tplace layer). The diagonal line is to mark the cathode of the LED. Can someone tell me what those lines are for?
Mike
    It certainly is not clear.
    Have a look at
    http://www.cree.com/sitecore%20modules/web/~/media/Files/Cree/LED%20Components%20and%20Modules/XLamp/XLamp%20Application%20Notes/XLamp_PCB_Thermal.pdf
    Page 20 has a MX footprint that I would go with. You will see that the
    dimensions have the same values as those you cannot explain in your image.
    All the best
    Warren
  • sailmike1
    0 sailmike1 over 11 years ago in reply to autodeskguest
    That's much better. Thank you for finding that for me! There's still some unexplained dimensions on there though.
    I don't know how to make the cross pads that form an "I" as I point out in the attachment. Also, I'm assuming the holes are plated. Do you know how to add these parts?
    Mike
    Fullscreen contentimage_176396.html Download
    <html><head><title>Jive SBS</title></head>
    <body><font face="arial,helvetica,sans-serif">
    <b>Error</b><br><font size="-1">
    An general error occurred while processing your request.
    </font></font></body></html>
