EAGLE User Support (English) Eagle library
  • Replies 7 replies
  • Subscribers 178 subscribers
  • Views 548 views
Eagle library
Is it possibel to print a survey of a library ?.
I use Eagle 4.15
C.Nielsen DK
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4462 (20090927) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
    Former Member over 16 years ago
    Maybe this ulp will help. Open the ulp with a text-editor to see how to use.
    Tested with 4.16r2 & works fine
    r
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> skrev i en meddelelse
    news:h9oeoh$fe9$1@cheetah.cadsoft.de...
    r
    Thank you.
    In the info in the ULP, it is mentioned, that i should run libraryname.scr.
    I dont have this script.
    Carsten
    You will find it in the library folder
    note: a big lbr will create a number of boards beginning with "board1.brd"
    etc
    r
    news:h9ojf9$t4$1@cheetah.cadsoft.de...
    etc
    r
    No. I have no file named: libraryname.scr
    I have search my total harddrive.I have no file with that name.
    Carsten
    "libraryname.scr" means the name of the lbr you have opened to run the ulp,
    e.g. transistor.lbr -> ulp -> transistor.scr. Try to search for *.scr, you
    should find it.
    r
    etc
    r
    Carsten
    You must open the library you want to check.
    From there you run the ulp.
    If the name of your library is "xyz" then the file CREATED ist "xyz.scr".
    That is meant with "libraryname.scr" image
    Then you open a new empty board.
    From there you run the "xyz.scr"
    Gruß / regards
    Joern
    "Joern Paschedag" <jpaschedag@t-online.de> skrev i en meddelelse
    news:h9pp8u$tge$1@cheetah.cadsoft.de...
    "board1.brd"
    etc
    r
    Carsten
    Gruß / regards
    Joern
    It works now. image
    Thank you very much for your help.
