EAGLE User Support (English) Rename all parts at once in schematic
  • Subscribers 187 subscribers
  • Views 1818 views
I have a schematic in which I need to change partnames. Unfortunately
some partnames are already taken. Is there a possibility to change in
one batch every partname?
At this moment when I change the name of a part I must change another
part in order to use this name. Thank you.
    You can do an automatic renumbering by running this ULP:
    renumber-sheet.ulp
    If you want to number by hand you can use the same ULP but tell it to
    start at a value higher than the highest number in any of your parts,
    for example at 1000. Then it assigns R1001, R1002, and so on. Now you
    can go in by hand and number any one of them R1, R2, and so on because
    the number will no longer be occupied by another part (they are all
    above 1000).
    Regards, Joerg
