EAGLE User Support (English) [Eagle 5.5/5.6, Linux/Windows] Printing to file changes size of the PCB layout
  • Replies 7 replies
  • Subscribers 179 subscribers
  • Views 526 views
I am a user of Eagle 5.5 and 5.6 under FreeBSD system -- Eagle works
quite well in Linux compatibility mode (so called Linuxolator) here.
For the sake of this report I used Eagle 5.5 and 5.6 under Windows.
I get the same problem in both cases.
I wanted to get a sheet ready for termotransfer method, so basically in
"Display", I picked "None" and selected: "Bottom", "Pads", "Vias".
Then, from "Print" I picked "Printer", I've chosen "Print to file" and
pointed out the PDF output.
The output is smaller than the original one by almost one pin distance:
     http://freebsd.czest.pl/~wkoszek/eagle/eagle_55_and_56.jpg
     http://freebsd.czest.pl/~wkoszek/eagle/eagle_55_and_56_2.jpg
Is it a known problem? My printer is Samsung ML-1610.
Wojciech A. Koszek
wkoszek@FreeBSD.czest.org
http://FreeBSD.czest.pl/~wkoszek/
    Wojciech A. Koszek wrote:
    You should be using the cam output to post script then print that.
    Printers may have scaling problems but only a few percent.
    Paul R.
    autodeskguest over 16 years ago in reply to autodeskguest
    in "Display", I picked "None" and selected: "Bottom", "Pads", "Vias".
    Paul R.
    Yes, this is typical procedure. However...
    "drill-aid.ulp", which I use to prepare the PCB image for hand drilling
    generates "centerDrill" layer numered 116, which makes PCB pads to have
    correct hole size.
    I save a PCB layout (otherwise, "centerDrill" isn't visible in the CAM
    tool -- once I close Eagle and open it once again Eagle finally
    presents "116  layer in the CAM tool).
    In the CAM tool, I select following layers:
    - bottom
    - pads
    - vias
    - centerDrill
    No matter whether I select "Fill pads" or not, "centerDrill" layer
    simply isn't printed.
    Wojciech A. Koszek
    and pointed out the PDF output.
    Paul R.
    correct hole size.
    - bottom
    - pads
    - vias
    - centerDrill
    After Googling this evening, I have found solution to this problem, and
    I can respond to myself and save some time for other people.
    Pasting this:
         http://www.mikrocontroller.net/attachment/39392/eagle-def.txt
    to bin/eagle.def lets you to pick "PS-Drillaid" as "Device" in CAM tool
    and this lets to see 116th layer to be present in CAM tool correctly.
    Wojciech A. Koszek
    I noticed Eagle unconditionally uses /usr/bin/lpr as a print program.
    In FreeBSD, /usr/bin/lpr is the "old" program dealing with parallel port
    printers.
    When you want to use your USB printer, your have to install CUPS
    package, and it will bring "lpr", but in /usr/local/bin/lpr.
    Programs like "xpdf" have nice option called "Print with command". Maybe
    we could have something similar in Eagle? Right now I just had to hack a
    /usr/bin/lpr to be a script calling /usr/local/bin/lpr.
    Thanks.
    Wojciech A. Koszek
    wkoszek@FreeBSD.czest.pl
  • kcadsoft
    kcadsoft over 16 years ago in reply to autodeskguest
    printers.
    EAGLE uses Qt to access the system's printing facilities, and that
    uses CUPS if it is present. Maybe the CUPS implementation on FreeBSD
    is not done in a way that a Linux program could properly detect it?
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    autodeskguest over 16 years ago in reply to kcadsoft
    printers.
    Klaus Schmidinger
    Printer seems to be detected: lp@. And basically it is the
    same stuff I see in other programs.
    I just see that just after hitting "OK" in Print dialog, /usr/bin/lpr is
    executed. And in terms of FreeBSD, it is the wrong program.
    /usr/local/bin/lpr should be used instead, if present.
    And this is what I see in vim(1), when editing "eagle" binary:
    @/usr/bin/true@-P@-o@media=@Collate=True@sides=two-sided-long-edge@sides=two-sided-short-edge@-J^@
    /usr/bin/lpr
    @-d@-s@/usr/bin/lp@0
      .3 -1 0 0 Tm
    Wojciech A. Koszek
  • kcadsoft
    printers.
    Klaus Schmidinger
    Printer seems to be detected: lp@<my hostname>. And basically it is the
    I'm afraid I have to disagree.
    If you have CUPS installed, /usr/bin/lpr should call a CUPS
    printing program.
    Klaus Schmidinger
