EAGLE User Support (English) ** 2 Power Sources on Single-sheet Schemati c ***
  • Subscribers 187 subscribers
  • Views 150 views
Guys, probably a quick answer from the more experienced users or tech team.
I have two sources of voltage coming into a single sheet schematic on a
DB9 connector.  One pin is 5VDC, another one is 24VAC.  Can EAGLE support
two distinct VCC sources on a schematic page?
If not, I guess the proper way to handle is to have any ICs that are using
VCC for +5VDC to get autorouted and anything that needs 24VAC gets specific
NETs to the supply pin, correct?
Gordon Hope
    Yes
    Gordon Hope
    See help invoke to get the hidden VCC pins placed on the sch.
