EAGLE User Support (English) CAM job getting corrupted
  • Subscribers 178 subscribers
  • Views 194 views
Hi All,
I am having some problems saving my own CAM jobs.
I have started using BatchPCB, so I decided to set up a CAM job that spits
out all the files they need in the right format.
I loaded the default Excellon.com job, made notes.
I then loaded the gerb274x.com job, then immediately saved it as
batchpcb-2-layer.cam.
I made all the changes, added the excellon section. I then went around teh
loop of running the job, making tweeks, saving, rerunning and so on.
I verified my gerbers, they are all perfect, so i saved the job, then quit
the CAMprocessor.
I then went back to the CAM processor because I'd made a tweek, tried toload
the job as was told :
c:\Program Files\Eagle-5.6.0/cam/BatchPCB-2-layer.cam(3): Syntax Error!
Not very helpful.
SO i went around the loop, repeated all the of the above, made another cam
job, then tried to reload it and got the same thing.
I attach my camfile and the originals i used to create it.
Can anyone suggest where I might be going wrong? (The error message
certainly doesnt)
Chris
    Former Member over 16 years ago
    "Chris Styles" <chris.styles@arm.nospam.com> wrote in message
    news:hdk1i6$801$1@cheetah.cadsoft.de...
    Hi All,
    the CAMprocessor.
    toload the job as was told :
    Not very helpful.
    certainly doesnt)
    Chris
    Hi Chris,
    It has something to do with your header/description.  When you copy the
    original back into your revised .cam job, it works.  I haven't taken the
    time to see exactly what the issue is, but that is a starting point!
    Terri
