EAGLE User Support (English) Best way to reverse a LM317 or TIP42C NPN Transistor
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 1213 views
I would like to reverse a LM317 or TIO42C.  I would like to add a
polygon and mount the LM317 on the bottom and use the polygon as a built
on heat sink.  I could save money on adding a heatsink and also make the
board thinner by not having to have the component stand up.  Is this
do-able?  Thanks
Carroll
    Travis G wrote:
    If this is a LM317: is 13.5V the input or output voltage? And if it's
    output, what is the input voltage?
    Travis
    Output, input of 17V
    PCB copper area needed to keep the part at or below 100degC under
    natural convection is about 26cm^2.
    Travis
    Thank you.  I'll give it a shot.
    Travis
    Travis
    Travis G wrote:
    On 11/14/2009 10:57 PM, cjolly wrote:
    Thank you for your response. Believe it or not, I woke up with the
    answer.
    Looking at the top of the board, I have the component with the pins on
    the left side and the body on the right. If I flip the component over
    vertically as I first thought, it will be on the solder side of the
    board, but pins 1 and 3 will be incorrect. However, if I shift the
    traces to the right side and flip the component horizontally
    and solder the pins on the trace side, it lines up the way I want it. I
    know there are a lot of factors invoived, but do you think 1.5 square, 1
    ounce copper will be enough of a heat sink for 13.5 volts, .5 amps?
    Thanks again.
    Carroll
    Travis
    Thank you for your response. Believe it or not, I woke up with the answer.
    Thanks again.
    Carroll
    Travis
    square, 1 ounce copper will be enough of a heat sink for 13.5 volts, .5
    amps?
    Thanks again.
    Carroll
    Vidar(Z) wrote:
    built on heat sink.  I could save money on adding a heatsink and also
    make the board thinner by not having to have the component stand up.
    Is this do-able?  Thanks
    Carroll
    Reverse it where? in the .sch or .brd?
    In schematic use MIRROR, ROTATE or just MOVE and right mouseklick.
    Nearly same goes for board except that MIRROR moves the component to
    the bottom side of the pcb.
    Polygon is no problem as a heatsink. Just draw the form. If you want
    the polygon be connected with other signals, gnd i.e., you must give
    the polygon the same name. To calculate the polygon area, you use
    RATSNEST, but this has to be activated in the options of eagle.
    Right now I cant answer for sure since My Eagle is not up and running
    thus I can not check my 2 cent but as I understand it you only find the
    vertical version and not the horisontal version of the package.
    As far as I know there should be an horisontaly version in the library
    or atleast an part which is similar in function and uses the same
    package but which package is horisontaly.
    Use Technology option to change package.
    Offcourse there is also always an option to enhance the library.
    Breg
    Vidar(Z)
    Carroll
    Nearly same goes for board except that MIRROR moves the component to the
    Polygon is no problem as a heatsink. Just draw the form. If you want the
    polygon be connected with other signals, gnd i.e., you must give the
    polygon the same name. To calculate the polygon area, you use RATSNEST,
    Breg
    Vidar(Z)
    do-able?  Thanks
    Carroll
    Gruß / regards
    Joern
