EAGLE User Support (English) Via stitching to bottomside ground plane
  • Subscribers 187 subscribers
  • Views 1322 views
Hi All,
I'm in the process of designing a 2-layer RF board, with RF signals routed
on the top side and a nearly full ground plane on the bottom side.  I'd
like to be able to stitch vias to ground on either side of the RF signals
on the top-side.  My first method of doing this was to simply run my RF
tracks, create my ground plane polygon on the bottomside (with thermals
off), place the vias where I want them, and re-name the net associated with
the via so that it is now the ground net.
This method seemed to work, until I did a rip-up of the ground to modify a
few items.  Of course, all my via stitching went away too.  I tried several
other ideas, but the only one that I could come up with that worked was to
actually create a "ground stitch" device in a library, followed by placing
one of these devices in the schematic for every ground stitch I wanted (and
there are a lot).  Then, when I go to layout, the stitching is all there
(and stays there) even when I do a rip-up of ground.
I'm guessing there is a better way that doesn't force the schematic to have
tens (if not hundreds) of these stitching devices represented, but I
haven't found it.  Any ideas?
Thanks much,
    autodeskguest over 16 years ago in reply to autodeskguest
    Thanks for the quick response James.  I was just playing around a bit more,
    and realized that the ripup command only operates on visible layers.  So,
    it works just fine to simply de-select the via layer before ripping up
    ground.  This will preserve the via placement (even though their net is
    still ground).  Much better solution compared to adding a boatload of
    "ground stitch" devices on the schematic.
    Of course, if you forget to de-select the via layer prior to running a
    ripup command on ground, a simple undo will take you back.
    Thanks again,
    jorlando wrote on Wed, 18 November 2009 13:35
    Hi All,
    routed on the top side and a nearly full ground plane on the bottom side.
    I'd like to be able to stitch vias to ground on either side of the RF
    signals on the top-side.  My first method of doing this was to simply run
    my RF tracks, create my ground plane polygon on the bottomside (with
    thermals off), place the vias where I want them, and re-name the net
    associated with the via so that it is now the ground net.
    modify a few items.  Of course, all my via stitching went away too.  I
    tried several other ideas, but the only one that I could come up with
    that worked was to actually create a "ground stitch" device in a library,
    followed by placing one of these devices in the schematic for every
    ground stitch I wanted (and there are a lot).  Then, when I go to layout,
    the stitching is all there (and stays there) even when I do a rip-up of
    ground.
    have tens (if not hundreds) of these stitching devices represented, but I
    Hello John,
    When I need via stitching I do just want you did.  You can ripup just one
    trace of a signal (including ground) without ripping up everything to do
    with the signal.  If you ripup an airwire it will ripup everything on the
    current trace (with some heuristics applied I think to figure out what is
    ripped up).
    See "help ripup" to get more info about how the command works and the
    various ways to filter how it behaves.
    You library device idea will work except it's a lot of work if you have a
    lot of stitching.  You could create one device that has the all the vias
    you want but then you'll get all kinds of DRC errors because (currently)
    there is no way to associate copper other than SMD or PAD in a package with
    a signal name.  So the DRC sees those as an error.
    Hope that helps...
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specialising in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
