EAGLE User Support (English) Flexible circuits
  • Subscribers 187 subscribers
  • Views 1246 views
Flexible circuits
I've been using eagle for a number of years now and am reasonably proficient
with it.  Recently I've come accross an application where a flexible printed
circuit (FPC)  would be ideal.  I've never designed these before.  What
special considerations need to be made for FPC circuits in eagle?  I've come
accross a design guide for FPC which has some good advice, but I have a few
specific questions.  For instance how do I show where cable stiffeners must
be placed?
    Martin Eder wrote:
    "Greg Wood" <greg.wood@NOSPAMshaw.ca> wrote in message
    news:he6c2m$p4q$1@cheetah.cadsoft.de...
    proficient with it.  Recently I've come accross an application where a
    flexible printed circuit (FPC)  would be ideal.  I've never designed
    these before.  What special considerations need to be made for FPC
    circuits in eagle?  I've come accross a design guide for FPC which has
    some good advice, but I have a few specific questions.  For instance
    how do I show where cable stiffeners must be placed?
    I never did a Flexiable circuit but, You can add a layer for the
    stiffeners and in addition to the gerbers, provide a layout drawing
    showing the placement of the stiffeners. I normally make a drill drawing
    for quoting, so the stiffeners would become part of it.
    Or you can just ask the vendor for what information he needs.
    Cheers
    I recently did a rigid-flex assembly (still not back from fab so I can't
    claim success!) and ran into a couple of issues w/ Eagle and flex.
    Regarding the issue of stiffeners,  I had a similar thing w/ the rigid
    sections.    I created a separate library part for the rigid sections
    and used the dimension layer only to show the flex boundaries.   Since
    its a rigid-flex assembly you have more layers where theres a rigid
    section but I did not figure out a good way to have Eagle take care of
    this for me so I had to manually check.
    A second thing is that for flex the power/gnd plan fill should not be
    solid...the fabricators like cross-hatch.   Eagle can do hatch fill
    polygons but these are always oriented with the x-y axes whereas for
    flex layout you could like the cross-hatch on the diagonal.    Someone
    in this forum suggested rotating the whole PCB by 45,  then ratsnest and
    generate gerbers.    I then used my gerb editor to rotate everything
    back by -45 degrees which gives me the diagonal fill pattern desired.
    Jim
    Cheers
