EAGLE User Support (English) [newbie] Wire bridge (manual drawing)
  • Subscribers 178 subscribers
  • Views 525 views
how do I draw board with wire bridges? I mean only one copper layer +
wires. I'am trying to design really simple circuit and 2-layer would be
"overkill". Don't need autorouter.
In list archive i have only found that it is possible in autorouter (but
does not work for me on "singlesided" example).
Eagle 5.6.0 Lite / Windows XP SP3.
W.P.
    W.P. wrote:
    W.P.
    Very simple. Use the two layer setup but assume all the top traces will
    be jumper wires.
    Paul R.
    "overkill".
    Simply use the top layer to draw the connections. Eagle does not care
    if you etch copper traces or solder wires. Just make sure your vias
    are large enough to drill and solder. Default via size may be too
    small.
    RoRo
    W.P. schrieb:
    W.P.
    With or without autorouter you can use a 2-layer board concept, because
    in this case the top layer IS your wire bridge.
    The only thing you have to watch is that the top layer nets are drawn
    straight image
    Gruß / regards
    Joern
