EAGLE User Support (English) putting copyright symbol in PCB
  • Replies 12 replies
  • Subscribers 190 subscribers
  • Views 3883 views
I'd like to put the copyright ("c" within a circle) symbol within text on a
PCB, like this:
I tried to use the ascii character copied into the clipboard and in the text
info dialog window it shows fine, but on the PCB it is a comma-looking
character.
I know that I could manually draw it, but then if I move it around there is
a greater chance I'll not properly copy all the pieces.  I could also make
it a package, but again it would then be seperate from the text that may
move around the board throughout layout.
Is there a more inherent internal mechanism to support high-order ascii
characters such as the copyright symbol?
thanks,
..dane
    All vector fonts are implicitly scalable independently in X and Y, and
    hence aspect ratio. Their only problem comes when trying to sample them
    into a raster at small sizes, so the EAGLE vector font should be able to
    easily adjust aspect ratio, if they would permit it.
    The Hershey font you are thinking of is Roman Simplex, the same vector
    font that used to be included with Windows 95,98, etc.
    I don't dislike the EAGLE vector font, but yeah, could be a little narrower.
    I have them all, in .fnt format even, if anyone wants....
    Oliver Betz schrieb:
    Please note that ulrimately when generating production output,
    like Gerber files, for instance, you might end up losing those
    characters again, because they are not supported by Gerber.
    Not if they were existent in the vector font.
    However I do agree that the expense of integrating 8 bit fonts is not
    reasonably related to its advantages.
    one problem is that you had to choose one character set and there will
    be customers wanting another one... You need UTF8 these days if you
    want to provide more than 7 bit.
    I first had written something like this, too - but then reduced it to
    the simple statement about expense/advantage ratio...
    I would rather like hershey font characters for the lower 7 bits...
    Would be nicer than the current font, although I don't care much about
    font cosmetics on boards and schematics.
    The most important criterion for me is to get the smallest possible
    text for a given minimum trace width. The Eagle font with 15% ratio
    did a good job regarding this.
    Do you think that there are better suited Hershey fonts?
    Hershey created many fonts. The one I think of is much like
    Helvetica/Arial, but rather narrow. I don't know its name, however... I
    would have to look up my CP/M archives; I once had a program there that
    used these fonts for creating very nice looking printouts - somehow
    similar to the TeX method.
    Most of the time, the EAGLE vector font simply is too wide, it wastes
    space that I don't have on the boards.
    Tilmann
    Oliver
    Using only 7bit ASCII characters saves you a lot of trouble image
    In the current situation: yes.
    Tilmann
  • kcadsoft
    kcadsoft over 16 years ago
    On 11/25/09 20:01, dane wrote:
    Draw a bitmap (add your logo as well) and import it using one of the
    ulp's
    that is coming with Eagle.
    Why not simply draw an arc and a circle?
    I can do both of these, however it is a minor nusiance to have to group all
    of the pieces when I wish to move it somewhere else.   I was hoping Eagle
    would support high-order ASCII characters for ease-of-use, that's all.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    ulp's
    thanks,
    ...dane
    It could be made with a no pin lib part with different sizes as a
    different package. To keep it all together add the year and company info
    then it is all one item when editing. I have not used the Ver 5's new
    attributes but a lib part with the circle C with year and company
    attribute would be a nice addition to anybodies lib.
    Paul R.
    ulp's
    thanks,
    ..dane
  • kcadsoft
    On 11/24/09 09:47, Morten Leikvoll wrote:
    "dane" <dane.ulp@lewisinnovative.com> wrote in message
    news:hee8jt$3kh$1@cheetah.cadsoft.de...
    Draw a bitmap (add your logo as well) and import it using one of the ulp's
    Klaus Schmidinger
    With vector font (used for production in combination with the cam-processor)
    it is not possible to use ascii > 127. This is written somwhere in the
    manual image
    r
