EAGLE User Support (English) SMD Pads Merged with Polygon
  • Subscribers 177 subscribers
  • Views 951 views
I have another rookie question.
Attached is a picture showing a simple rectangular PCB with two components
on it.  I want to use the polygon comand to create a plane that touches the
SMD Pads as much as possible.  Creating the Polygon on the top layer and
using the name command I change the Polygon signal name to match the trace
connecting the two SMD Pads. When I Ratsnest, the SMD Pad is seperated from
the Polygon.  How do I change this?
The components have the STOP turned off when the SMD pads were created.
Jason
    i think you want thermals OFF for the polygon, that might fix it.
    Jason
    Notice the small lines connecting it to the polygon? That is matching
    the polygon's width and isolate. If isolate is too big, or width is too
    small, you can have problems. I commonly use both set to anywhere from 8
    to 16mils, depending upon several things.
    Travis
    "Jason" <jason@putco.com> wrote in message
    news:hf9ca1$n7n$1@cheetah.cadsoft.de...
    the SMD Pads as much as possible.  Creating the Polygon on the top layer
    and using the name command I change the Polygon signal name to match the
    trace connecting the two SMD Pads. When I Ratsnest, the SMD Pad is
    seperated from the Polygon.  How do I change this?
    Jason
    THANKS!
    That was it!
    Jason
