EAGLE User Support (English) change key binding for "alternate grid" ?
  • Subscribers 178 subscribers
  • Views 270 views
I'm using eagle 5.6.0 light under linux and I would like to change the key
binding for "alternate grid".
At the moment one can use the "ALT" key to temporarily switch to alternate
grid size.
However, unfortunately under linux this key is bound to the window
manager.
For this reason I would like to change the key to something else.
Is this possible ?
I guess I can do something like this in Options->Assign ?
cheers,
stefan
  • Richard_H
    Richard_H over 16 years ago
    stefan schoenleitner schrieb:
    grid size.
    manager.
    Is this possible ?
    cheers,
    stefan
    You can't change the ALT key within EAGLE.
    You could assign a key for switching to the alternative grid:
    assing C+G  'grid alt inch 0.01'
    But in this case, you have to assign a second key to come back
    to the grid used before. For example:
    assign C+L 'grid last'
    HTH
    BTW: Couldn't you change the key assignment of your window manager?
    Which one do you use?
    Richard Hammerl
