    • Avnet Boards Community
EAGLE User Support (English) Install Eagle 4.09 on Win7 x64
  • Replies 11 replies
  • Subscribers 173 subscribers
  • Views 2655 views
autodeskguest over 15 years ago
Does anyone have experience installing / running Eagle on Windows 7, 64 bit
edition?. The Cadsoft site mentions Windows 7 for 5.x series but not
specifically 32bit or 64bit systems. I currently use 4.09 professional which
won't install. Using a compatibility mode and/or running as administrator
doesn't help. I now use Windows 7 XP mode (Virtual PC) and that seems to
work fine, but i'd rather use native Win7 install (it's a bit quicker
starting / closing).
So maybe it's time to upgrade to 5.x (I'm a hobbyist; it's a lot of
money...), but, of course, only if it runs without problems on W7 64bit.
Richard
__________ Informatie van ESET NOD32 Antivirus, versie van database viruskenmerken 4732 (20091231) __________
Het bericht is gecontroleerd door  ESET NOD32 Antivirus.
http://www.eset.com
    On Sun, 3 Jan 2010 22:11:33 +0100, Richard Herman wrote:
    Just as a sanity check (if I can't make it work...), did you use the 64bit
    edition, to test this?
    Yes, my desktop PC (which I used for this test) is running Windows 7
    Ultimate 64bit. With 12 GB ram in it, 32bit isn't an option.
    And by the way: I am using Eagle 5.6.0 on this machine without any
    problems at all. I only tried to mess around with 4.09 to see if I
    could find a solution for you. So rest assured, if all else fails, an
    upgrade to 5.x works fine.
    You could try the freeware version of 5.6.0 yourself, and see if it
    works on your Win7.
    Mikael Ejberg Pedersen
    http://www.ejberg.dk
