EAGLE User Support (English) How can I print a negative image of the   PCB
  • Subscribers 177 subscribers
  • Views 1602 views
does anybody know how can I print a negative image of the PCB to the local
printer any help 01is very much appreciated, Thanks Mitch
    andermma wrote on Fri, 01 January 2010 08:21
    local printer
    Turn on just the layers you want in the print, then use FILE > EXPORT >
    IMAGE and check MONOCHROME.  Now you can use ordinary image tools to flip
    black and white, mirror, rotate, etc.
    autodeskguest over 15 years ago in reply to autodeskguest
    Hi, thank you!! That works - u do need to have a graphics program that will
    print it correctly - photo shop is able to. I also found that if the board
    background in eagle is set to black and you select monochrome and save the
    image it will save a negative image and if you have a white background it
    will be a positive image.
    Thanks Again
    Mitch
