I try to output some files from an ulp, in a specific folder. I can create
the desired path, but "output" function don't create the folder.
I can use the "dlgDialog" function to create the folder, but I don't want
this aproach.
this aproach.
"eSilviu" <silviu.epure@ugal.ro> wrote in message
news:hhsh7j$fq9$1@cheetah.cadsoft.de...
this aproach.
WELL, IT SEEMS THAT USERS THAT ASK HOW TO MOVE A COMPONENT FROM TOP LAYER TO
THE BOTTON GET ANSWER.
When someone puts a question with not-so-obvious solution, nobody try to
answer.
This can't be named "SUPPORT".
this aproach.
answer.
It's our first day back in the office after the Christmas break, and
we're in the process of answering the postings right now. So a question
from an other user got answered before yours - is that a reason to become
loud? What's wrong with answering simple questions first?
Klaus Schmidinger
Klaus Schmidinger Phone: +49-8635-6989-10
CadSoft Computer GmbH Fax: +49-8635-6989-40
Pleidolfweg 15 Email: kls@cadsoft.de
D-84568 Pleiskirchen, Germany URL: www.cadsoft.de
On 01/04/10 11:52, eSilviu wrote:
this aproach.
There is currently no direct function to create a new folder from
a ULP. What you can do at te moment is to use the system() function,
like in
system("mkdir foldername");
We are planning to implement an mkdir() function in a future version.
Klaus Schmidinger
"Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
news:hi737i$hf5$1@cheetah.cadsoft.de...
create
this aproach.
like in
Klaus Schmidinger
Widows XP:
string filePath;
if (board) board(B) {filePath = filedir(B.name);}
filePath=filePath+"output";
string comanda="mkdir "+filePath;
system(comanda);
Will give me the following command to be sent to OS:
"mkdir D:/Documents/Proiecte/2009/temp/555/output"
witch... is wrong, since "\" should be used, not "/"
So,.. any other ideas?
PS: problem is not the mkdir() function (that does not exist), but the
"output()" function, that can't create path do the desired file.
create
this aproach.
like in
Klaus Schmidinger
Widows XP:
string filePath;
system(comanda);
Oh well, one of those "original sins" of Microsoft...
You can do
string a[];
strsplit(a, filePath, '/');
filePath = strjoin(a, '
Klaus Schmidinger
Klaus Schmidinger wrote on Fri, 08 January 2010 06:00
Won't that pop up that dialog warning the user that a ULP is trying to
execute a system program? That would get annoying really fast.
"Olin Lathrop" <eagle@embedinc.com> wrote in message
news:hia7oh$2mu$1@cheetah.cadsoft.de...
already annoying from the first apparition.
and IMHO, you can't put a SO in danger if you create a folder, so that user
to give the accept for this. (even if you create 1000 folders, I don't see a
major security problem)
