EAGLE User Support (English) Orcad to Eagle netlist conversion
  • Subscribers 178 subscribers
  • Views 554 views
I have an Orcad Capture 9.1 design and need to convert the netlist to
Eagle Ver 4.16r2 Professional (Linux Version) for PCB layout.
I have done this before, over 2 years ago, but have forgotten how I did it.
So, my questions are:
1. What netlist format should I use in Orcad ( I think I used Multiwire
last time)?
2. What ULP, or conversion program should I use (I'm sure I used
net_coversion in Windows)?
3. Can I erase the current airwires from a previously run scr file?
A beer for a good answer, 3 beers for the best answer!
Thank you
Ross
  • Richard_H
    Richard_H over 15 years ago
    last time)?
    Thank you
    Ross
    Please take a look at www.cadsoft.de/download.htm, ULP directory
    ==> importbom_and_netlist.zip
    or in the Misc directory
    ==> or2eag32.zip
    Maybe this helps.
    Concerning deleting signals:
    Type in the command line:   DELETE SIGNALS;
    Richard Hammerl
    autodeskguest over 15 years ago
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:hjc0pn$ct2$1@cheetah.cadsoft.de...
    did it.
    Multiwire
    last time)?
    Thank you
    Ross
    ==> or2eag32.zip
    Maybe this helps.
    Is convert.exe still bundle with eagle? I usually use that with
    multiwire.
  • Richard_H
    did it.
    Multiwire
    last time)?
    Thank you
    Ross
    ==> or2eag32.zip
    Maybe this helps.
    multiwire.
    xconvert.exe in no longer part of the EAGLE installation. It was
    developped about 20 years ago as a simple DOS tool and has been
    dropped with EAGLE 4.0 or 4.1.
    Richard Hammerl
