EAGLE User Support (English) Drawing wire on a layer
  • Replies 12 replies
  • Views 1362 views
(using 5.7.0)
When I draw a wire between two points, it seems to connect to airwires at
the end, even if there is no net/smd on that that layer in any of the wire
ends. (If there are two different airwires at each end, it refuses to draw
the wire.)
I agree it should connect to the airwire if there is a pad/via or net/smd at
the same layer you are drawing, but I think it should start a new netname if
there is no natural connection.
Am I missing some advantages the way it is done now?
[In addidtion, I think this connecting should also happen for every wire
when you paste stuff over existing airwires... Or at least ask you if you
want to do that]
  • kcadsoft
    kcadsoft over 16 years ago
    On 01/25/10 20:23, Morten Leikvoll wrote:
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:hjk9dq$ns4$1@cheetah.cadsoft.de...
    Fixed for version 5.7.1:
    - Fixed wrongfully adding a wire to an existing signal if the wire is
    placed
       at a point where a connected SMD pad exists on a different layer.
    Will this also fix the case if you have end of sig1 on layer2 AND end of
    sig2 on layer3 on the same point, while drawing a wire from that point on
    layer4?
    This should never have been a problem.
    The problem was only with SMDs where airwires ended.
    Can you send me an example that demonstrates the problem you are
    seeing?
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    "Olin Lathrop" <eagle@embedinc.com> wrote in message
    news:hjk909$m6o$1@cheetah.cadsoft.de...
    Morten Leikvoll wrote on Mon, 25 January 2010 07:29
    Every time you comment my stuff, you are teaching me to do things YOUR
    way..
    Please stop that image
    You seem to be going out of your way to use Eagle in ways it wasn't
    intended, then complain when it doesn't work.  Try embracing the tool
    instead of fighting it.
    I try. Strangely enough I learn new things even after 10+ years of use.
    Quote:
    I used this to strengthen some polygon fills.
    It's still not clear what "this" is.  Maybe a picture would help.
    The topic is already dying, but I am referring to the fact that drawing
    wires at existing signals, kinda functions as a route. The new wire will
    become a signal with the name of the net you started drawing from (and/or
    to). This "net merging" is what behaves strange as it doesnt compare the
    layer of the wire you draw with the layer of the signals you draw from/to.
    Since points can have several nets on one point (in different layers), this
    fails in those cases.
    Quote:
    The general spacing I use doesnt make the fill between some via's, but
    I accept some smaller clearance at some places, and therefore use wire's
    between those via's (and rename it to whatever I want) to make the
    airwire disappear (after ratsnest).
    So if I understand this right, you have a polygon with a certain spacing
    parameter.  That spacing causes the polygon to be broken up near some vias
    because there isn't enough clearance to flow between them?  And in some of
    those cases you want to manually add the trace because you know the
    clearance is really OK in those areas?  If that's the case, you could have
    just said so.  If not, then I'm still confused and a better description is
    still needed.
    The problem was that there wasn't a problem getting things done. It was just
    a weird behavior from eagle in some special cases.
    If the above guess as to what you really want is correct, then I still
    don't see why you need to use WIRE instead of ROUTE as intended by Eagle.
    There is a better chance Eagle understands the connections made by ROUTE,
    and the user interface regarding airwires should be clearer.  Have you
    tried ROUTE?  Either way you will get lots of DRC errors, so that
    shouldn't
    be the difference.
    Will ROUTE work from a polygon edge? I think not. A WIRE will, but it has to
    be renamed.
    Quote:
    You may discuss the correctness of this, but I'm not interested in
    hearing right now
    You started this thread.  Discussing the correct or best use of the tool
    is
    legitimate and relevant, whether you wish to hear it or not.
    I think I got Cadsoft's attention on the "problem" I saw, and I learned that
    I should get used to using ROUTE while holding CTRL in the other cases where
    I've been using WIRE. Case closed..?
    news:hjk99h$nq1$1@cheetah.cadsoft.de...
    Once again, it's still not clear what "this method" is exactly.  However,
    you should read the help on ROUTE again.  It is not constrained to start
    on
    airwire ends only.  If you press SHIFT or CTRL (can't remember which off
    the top of my head, see the help page) while clicking on the route
    starting
    point, it will start where you clicked, not the nearest airwire end.  If
    that's what you were trying to accomplish, then there is no need to use
    WIRE instead of ROUTE, and a bunch of good reasons not to.
    You are right there. That can be used for some of my cases where I need to
    start from a point where there is no airwire. I haven't really programmed my
    fingers to use that functions (old habits die hard) but I will. Its an
    easier way than using wire draw.
    It doesnt help me when cheating on the fill tho, but thanks.
    placed
    layer4?
  • kcadsoft
    On 01/25/10 10:48, Morten Leikvoll wrote:
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:hjjoco$4ua$1@cheetah.cadsoft.de...
    Morten Leikvoll schrieb:
    (using 5.7.0)
    wire
    draw
    the wire.)
    at
    if
    want to do that]
    I am sorry, but I read your message several times and I don't
    understand what you want to tell us. Could you please give me
    some more information and maybe send me an example for clarifying?
    Ok, I was afraid my explanation was a bit hard.
    First, imagine if you have two different airwires at the same point (at
    different layers). When you draw a wire (not route, but wire!) it will hook
    up to one of them. Uless the wire you draw is a continuation of an existing
    wire or pad, it just connects to one of the airwires (I do not know wich one
    it prefers). What I try to say is that in the case your wire is not meeting
    any other wires or smd's, it should not hook up to the airwire.
    Imagine this case:
    -You got two smd's next to each other on layer1
    -You route one of them out to a via and change to layer2, then route it over
    the second smd. Now you got 2 airwires at the same point.
    -Draw a wire (not route!) on layer3 from this point to anywhere. This will
    be hooked to one of the airwires. I think this should not happen. It should
    only happen if you draw at layer1 or 2, but not at 3.
    I hope this helps understanding the issue.
      - Fixed wrongfully adding a wire to an existing signal if the wire is placed
    Klaus Schmidinger
    Morten Leikvoll wrote on Mon, 25 January 2010 07:44
    I should add that I also use this method when I know where to route
    from,
    but airwire isnt starting there. It saves me a lot of time. Try it image
    you should read the help on ROUTE again.  It is not constrained to start on
    the top of my head, see the help page) while clicking on the route starting
    way..
    still needed.
    tried ROUTE?  Either way you will get lots of DRC errors, so that shouldn't
    be the difference.
    hearing right now
    You started this thread.  Discussing the correct or best use of the tool is
    news:hjk23o$jb6$1@cheetah.cadsoft.de...
    This still isn't making much sense.  I guess you are in the board editor,
    but why are you using WIRE instead of ROUTE to draw copper traces?
    Whenever you click on something and there are multiple options nearby,
    I've
    always seen Eagle highlight one of them, then right click cycles thru the
    available ones, then you left click to confirm the specific choice.  What
    happens when you use ROUTE?
    I should add that I also use this method when I know where to route from,
    Morten Leikvoll wrote on Mon, 25 January 2010 04:48
    hook up to one of them. Uless the wire you draw is a continuation of an
    existing wire or pad, it just connects to one of the airwires (I do not
    know
    wich one it prefers). What I try to say is that in the case your wire is
    not
    meeting any other wires or smd's, it should not hook up to the airwire.
    I've
    Every time you comment my stuff, you are teaching me to do things YOUR way..
    Please stop that image I know just as many tricks that works for me as
    you probably do for yourself.
    I  used this to strengthen some polygon fills. The general spacing I use
    doesnt make the fill between some via's, but I accept some smaller clearance
    at some places, and therefore use wire's between those via's (and rename it
    to whatever I want) to make the airwire disappear (after ratsnest). You may
    discuss the correctness of this, but I'm not interested in hearing right now
    It can be fixed by not drawing a wire between airwires, rather move the ends
    after drawing, so its not a dead critical issue, its just not right, and
    thats why I posted this.
    hook
    existing
    wich one
    meeting
    Whenever you click on something and there are multiple options nearby, I've
