EAGLE User Support (English) Different Net classses on GND?
  • Subscribers 178 subscribers
  • Views 1075 views
autodeskguest over 15 years ago
Example: I have a CPU and power suppy part on my schematic. The CPU is
connected to GND via GND symbol and gets assigned to my own defined net
class GND. The power supply is also connected to GND via GND symbol.
Here is the problem: I would like to have a net class with smaller width on
the CPU part GND (8 mil) and wider on the power supply (20 mil). However,
whenever they are connected together the apply to the same net class.
How do I split them to be connected to the same net but have different net
classes?
I have solved it temporary by having them separeted in different net GND and
GND_MAIN and then connected together with a resistor (0 ohm). Feels stupid
but I haven't understood how to separete them into different net classes in
any other way...
    "Per Green" <per.green@pipeguard.se> wrote in message
    news:hjt2bg$qbg$1@cheetah.cadsoft.de...
    on the CPU part GND (8 mil) and wider on the power supply (20 mil).
    However, whenever they are connected together the apply to the same net
    class.
    classes?
    and GND_MAIN and then connected together with a resistor (0 ohm). Feels
    stupid but I haven't understood how to separete them into different net
    classes in any other way...
    That is THE way to solve such issues. This way you can also place the 'star'
    point of your GND's (if you got more than 2) wisely when it comes to decent
    power layout. Normally this point is close to the power connector. Same goes
    for shield signal. Shield is just another GND connection where there is no
    currents flowing except discharge currents from connectors. If that is
    connected to gnd close to the power connector, you can avoid high current
    peaks going through the sensitive electronics. Hobbyists normally doesnt
    care about this, but pro's do.
  • ameliaamelia
    ameliaamelia over 15 years ago
    Yes the "resistor (0 ohm)" solution is the only available, but not so
    elegant.
    To route my PCb, I use a script like "auto Wire1; auto Wire2; ...",
    obtaining a good PCB, better than EAGLE auto; and also better the
    FreeRouting.
    The problem of "2 GND traks size" is similar to the "decoupling capacitors
    of an IC".
    I want a straight track from the capacitor to the IC.
    I suggest to the Eagle guys the following implementations:
    1- name a segment of wire like mailto:GND@MAIN mailto:GND@CPU
    mailto:VSS@PIN21 mailto:VSS@PIN34;
    2- class the segments mailto:GND@MAIN mailto:GND@CPU mailto:VSS@PIN21
    mailto:VSS@PIN34;
    3- auto GND;     if I want to route all GND wire's segment;
    4- auto mailto:GND@MAIN; if I want to route the single segment;
    amelia
    Per Green wrote on Thu, 28 January 2010 17:16
    GND and
    That works, but now you have another part that has to be loaded, bought,
    stocked, etc.
    I use Eagle devices I call "shorts".  They have two pins and just connect
    them together.  For the symbol I make a line just a little wider than a
    normal schematic wire.  I have several flavors for connecting only on the
    top layer, bottom layer, all layers, etc.
    The shorts library and a bunch of other Eagle stuff is in my Eagle tools
    release that is available for free from
    http://www.embedinc.com/pic/dload.htm.
    Hello
    I miss the net naming feature too:-) When using an auto router it must
    be there.
    classes?
    any other way...
