EAGLE User Support (English) Stop Mask Error - Silk Layer
  • Replies 11 replies
  • Subscribers 187 subscribers
  • Views 1556 views
I am getting the Stop Mask error on DRC because the silk screen layer and
text is overlapping the stopmask. Can I keep this and send to board
manufacturer, for automated assembly (maybe without silkscreen on the board)
or should I correct? I would be a big trouble to correct.
Thiago
    autodeskguest over 16 years ago in reply to autodeskguest
    On Mon, 1 Feb 2010, Thiago Henrique Rodrigues wrote to us saying :
    I just want to get rid of the errors and make
    it pretty easy to the PCB house to understand the board. I would appreciate
    some tips from someone who has boards manufactured all the time.
    It's best if you can provide a "perfect" silk screen Gerber that doesn't
    overlap any pads, but usually it doesn't matter. However, I would
    recommend making sure that the silk screen includes some useful stuff
    like component IDs and orientation. Sure the board house ought not to
    need that if it's being assembled in significant numbers (because it
    will be automatically placed). But my experience has been that board
    houses sometimes make mistakes, and if the silk screen makes it clear
    what goes where and which way round then they make fewer.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    Thiago Henrique Rodrigues wrote:
    "Gary Gofstein" <nospam@use.forum.net> escreveu na mensagem
    news:hk7efr$g00$1@cheetah.cadsoft.de...
    silk is also important in troubleshooting, but oh yeah, we never have that
    problem.
    seriously, thiago, as olin mentioned, almost all board houses will remove
    the silk from offending areas these days, check with yours regarding their
    policy. it's easy to miss small areas.
    do we have a ULP that does this?
    I see. Well this is my first board that is not for "amateur" purposes. I'll
    have it fabricated and assembled in scale, and I can't afford running into
    mistakes. The DRC error scare me, like something could go wrong during
    fabrication/assembly process. I just want to get rid of the errors and make
    Why don't you generate gerbers and submit the gerber set to
    www.freedfm.com.   Their tools will review your files and send you an
    email w/ what they deem to be pcb manufacturing problems.   If there are
    no "show stoppers" then chances are that Advanced Circuits could
    manufacture your board w/o difficulty.    Note that the automated tools
    do not look for potential assembly problems however....like very sort
    component in between two very tall ones.
    Jim
    problem.
    that problem.
    remove the silk from offending areas these days, check with yours
    regarding their policy. it's easy to miss small areas.
    Morten Leikvoll wrote on Mon, 01 February 2010 03:46
    IMHO silkscreen does more damage than good, unless you have very good
    reasons to have it.  I do high density stuff, and there is just not
    space for silkscreen. I do not really want to waste time positioning
    stuff that have no use.
    There are certainly issues with silkscreen and high density boards, but to
    make a blanket statement that silkscreen "does more damage than good" is
    just silly and possibly misleading to newbies.  Silkscreen can be very
    useful in decreasing human error.  Even if the entire assembly process is
    automated, the silkscreen can still help later in part identification,
    inventory, installation into the bigger system, etc.  It may not do much
    for your specific case, but there are many designs where it does help,
    which probably include the majority of boards designed by the people here.
    Thiago Henrique wrote on Sun, 31 January 2010 16:53
    I see. Please check the picture attached. I resized the silkscreen
    frame, it
    is inside the Stop Mask. What do you suggest? To resize the stop mask
    also?
    The holes in your solder mask do look quite large.  However, the numbers in
    the middle of each pad are the more serious problem.  Those should
    definitely not be on the silkscreen.  Put them in the tDocu layer if you
    really want them in the board drawing.
    "Thiago Henrique Rodrigues" <thiago_hr@yahoo.com.br> wrote in message
    news:hk4j80$llh$1@cheetah.cadsoft.de...
    board) or should I correct? I would be a big trouble to correct.
    If you don't need the silkscreen, just disable the values,names and place
    layers when running DRC and leave out the silk process in the CAM.
    reasons to have it.
    I do high density stuff, and there is just not space for silkscreen. I do
    not really want to waste time positioning stuff that have no use. The
    manufacturer has told me they don't need it.
    Also note that silkscreen may cause problems even if DRC does not detect
    errors. Say you have a very flat or small smd component and some silk under
    it, you may have problems getting both ends touching the pcb at the same
    time, cause the silk build slightly up under it.
    Robert Pearce" <news@bdt-home.demon.co.uk> escreveu na mensagem
    news:S9G6BYF1mhZLFwPv@daniel.huneausware.local...
    On Sun, 31 Jan 2010, Thiago Henrique Rodrigues wrote to us saying :
    I see. Please check the picture attached. I resized the silkscreen frame,
    it
    also?
    I would suggest doing the silk screen frame like most of the Eagle
    libraries. That is, the bits which should be clear of the stop mask (two
    short parallel lines) should be on the tPlace layer, while the bits that
    overlap the stop mask should be on the tDocu layer. This allows the
    designer to see the whole outline when placing components, but by
    excluding tDocu and bDocu from the CAM job you send a trouble-free silk
    screen to your board house. This does need a bit more up-front care and
    effort in creating library parts, but it makes life easier in the long
    run.
    believe a word.      |
    I switched the silk frame from tPlace to tDocu layer. The DRC is no longer
    generating errors. I hope this is ok for the pcb house.
    I see. Please check the picture attached. I resized the silkscreen frame, it
    is inside the Stop Mask. What do you suggest? To resize the stop mask also?
    run.
    believe a word.      |
    "Olin Lathrop" <eagle@embedinc.com> escreveu na mensagem
    news:hk4pko$es4$1@cheetah.cadsoft.de...
    Thiago Henrique wrote on Sun, 31 January 2010 13:47
    and text is overlapping the stopmask. Can I keep this and send to board
    Most board houses will automatically clip the silkscreen to the
    soldermask,
    but it's bad practice to rely on that and you need to check with the board
    house to be sure.
    Why is it "big trouble" to fix it the right way?  So far I haven't
    ecountered such a problem and it's hard to imagine how you'd run into one
    without something stupid going on.  If the offending silkscreen is coming
    from a name or value, then it's easy enough to move it, resize it, or
    delete it.  If it's coming from tPlace (or bPlace) in a library part, then
    that's a badly made part and should be fixed.  Library parts shouldn't
    have
    silkscreen so far outside their own outline that a pad of another part
    could be placed there.
