EAGLE User Support (English) scale a polygon
  • Subscribers 185 subscribers
  • Views 1652 views
scale a polygon
Is there an easy way to scale a polygon ?
I am using polygons to draw clean logos on silk or copper (with import bmp,
then drawing the polygon over it).
This process is rather boring when generating various size of the same logo.
I was wondering if there would be a way to scale the polygon, for ex using
ULP.
Taking as hypothesis that the origin of the footprint in the library is
either at the center or in a corner of the logo,
if each coordinate is scaled by x1,5 or x2,0 this would scale easily the
whole polygon.
Best regards,
Jerome Lamy
    Jerome wrote:
    Depends on what you call easy.
    ULP.
    whole polygon.
    Best regards,
    Jerome Lamy
    Put only the polygon on a board or lib and export it to a script. Use
    any programming language to scales the values of the script and then
    import it into a new lib.
    Paul R.
    Thanks Paul, it worked well.
    I have VB6 code available.
    Best regards,
    Jerome Lamy
    Put only the polygon on a board or lib and export it to a script. Use any
    programming language to scales the values of the script and then import it
    into a new lib.
    Paul R.
