EAGLE User Support (English) "Warning: More than one signal layer active!" when running a CAM job on  *.brd file
  • Replies 8 replies
  • Subscribers 189 subscribers
  • Views 2255 views
unebonnevie
unebonnevie over 16 years ago
I have a 2-layer (top and bottom layers) *.brd.  Is this the warning I get
when running a CAM job on a 2-layer design?  Thanks
  • userelement
    userelement over 10 years ago in reply to autodeskguest
    There is a series of YouTube tutorials containing 12 lessons for Eagle.  Search for Eagle Tutorial (RPC Electronics.
    If I remember right, lesson 12 deals with making Gerber files.
    In the Eagle board window, click "Cam Processor"
    In the new window that pops up, click "File", "Open", "Job"
    Find the CAM file that you want to run and click "Open"..  The file name must have the extension, "cam".
    Click "Process Job"
    One board house requires the following:
    1. Gerber Files Required:
    The following files would be needed for the 2-layers PCB production:
    Top layer:pcbname.GTL
    Bottom layer:pcbname.GBL
    Solder Stop Mask top:pcbname.GTS
    Solder Stop Mask Bottom:pcbname.GBS
    Silk Top:pcbname.GTO
    Silk Bottom:pcbname.GBO
    NC Drill:pcbname.TXT
    Mechanical layer :pcbname.GML
    Note: The Gerber file must be RS-274x format and board outline must be included at least in one layer;
    Compress the 8 files into one zip file and upload to your board house.
    https://www.youtube.com/playlist?list=PLDE1858BD83D19C70
    autodeskguest over 16 years ago in reply to autodeskguest
    Gary Gofstein wrote on Mon, 08 February 2010 19:32
    Another nice alternative for the hobbyist/noob is to just use a board
    house that will accept the eagle .brd file and skip the gerber process
    entirely.
    Some board houses do accept Eagle BRD files, but this is not a good
    solution.  It will severly limit the board houses available to you, and it
    leaves questions open as to what layers you really want (and will pay for),
    what exactly will be shown on the silkscreen, etc.
    The CAM processor in Eagle is not that hard to use.  Take the extra hour to
    read the documentation and follow the process once.  Then you'll have a
    better understanding what is going on and a whole world of possible places
    to get your boards done.
    autodeskguest over 16 years ago in reply to unebonnevie
    Time to stop relying on sparkfun and learn how to make CAM jobs. A CAM
    job generates a series of files that are printed onto the board through
    complicated processes to form the the traces, holes, vias, soldermasks
    and silkscreen legends.
    Each "Gerber" must represent one and only one process. So the top and
    bottom trace layers are separate processes because they are printed on
    separate sides of the board. My guess is that the CAM job you used
    included both Top and Bottom layers in one output file, leading to the
    warning. Normally, the component side gerber contains the top copper
    layer, pads layer and via layer. That is, anyplace you want to have
    copper on top of the board. The solder side gerber is the same except
    traces come from the bottom eagle layer. It's up to you what to put into
    the silk layers, usually tplace and tnames but you may want others, make
    sure all fonts in this layer are vector font or you will get a nasty
    surprise. The stop gerbers for soldermask are made the tStop and bStop
    layers usually.
    Most board houses do not want the bottom layer mirrored.
    By looking at the gerber files individually on a gerber viewer, you can
    often spot problems such as mirrored layers, offsets, inversions,
    scaling errors, wrong size holes, offset holes or missing layers. You
    can also output the gerbers to a printer and hold them up to the light
    to make sure they are what you need. What you see is what you get, if it
    looks wrong, it probably is wrong. There are ULP's to assist with this
    process.
    entirely. That's how I do it, had great luck so far with Beta Layout.
    Thanks, Sparkfun tutorials didn't say.  Only mentioned the
    sfe-gerb274x.cam file.
    Sorry for such noob questions, but my first board and I wanted to make
    sure everything is good.
    Thanks.
    I use a modified version of the Sparkfun cam file. I think it generates the
    drill file for you that why they don't mention the extra step in the
    tutorial Also, check your gerbers carefully with a gerber viewer as I seem
    to remember they don't output the component names to the top silk screen
    gerber.(I know something was missing??)
    I don't see what Sparkfun has to do with this.  You should be following the
    Eagle documentation.
    Quote:
    So, per this posting, I get ""Warning: More than one signal layer
    active!" when running a CAM job on *.brd file, that's because I have
    traces routed both the bottom and top layers.  Is that correct?
    Probably not.  You need to make a separate Gerber file for each layer of
    the board.  You can use my Generic2L CAM job, which is included in the
    Eagle Tools release I mentioned in your other thread.  That has the Gerber
    file outputs defined you would likely ever want.  Just temporarily delete
    the ones you don't need, run the job, then don't save it so all the layers
    are there to select from next time too.  Take a look at my EAGLE_PCB BAT
    file in the COM directory.  The comments contain a checklist of things to
    do to go from finished board design to board fab files for a board house.
  • unebonnevie
    "Olin Lathrop" <eagle@embedinc.com> wrote in message
    news:hkmk3r$t4c$1@cheetah.cadsoft.de...
    Quote:
    Actually one more question.  I ran the CAM job, I don't see the *.drd
    file, the drill file, generated.  I see the *.dri file generated.  Is
    that the drill file?
    If you had simply looked at it you would have seen it is the drill
    information file, not the drill data file.  You first run DRILLCFG, then
    the Excellon CAM processor job to create the actual drill data.
    Thanks, Sparkfun tutorials didn't say.  Only mentioned the sfe-gerb274x.cam
    file.
    Sorry for such noob questions, but my first board and I wanted to make sure
    everything is good.
    So, per this posting, I get ""Warning: More than one signal layer active!"
    when running a CAM job on  *.brd file, that's because I have traces routed
    (Also I was able to gerbv gerber file viewer and confirm all the details.)
    Thanks.
  • unebonnevie
    Actually one more question.  I ran the CAM job, I don't see the *.drd file,
    the drill file, generated.  I see the *.dri file generated.  Is that the
    drill file?
    "AL" <unbonnevie@yahoo.com> wrote in message
    news:hkm0q0$5n9$1@cheetah.cadsoft.de...
