EAGLE User Support (English) Pin numbers in Schematics
  • Replies 8 replies
  • Subscribers 177 subscribers
  • Views 835 views
autodeskguest over 15 years ago
Hi, Can anyone throw some light on how I can get the components' Pin Number
(not name) for a NET from within a ULP?
I've looked at the object definitions in the Help pages, but pin numbers
are not mentioned at all.
    radgoate wrote on Thu, 11 February 2010 08:46
    Number (not name) for a NET from within a ULP?
    numbers are not mentioned at all.
    If you just want a netlist and don't care about the format (other than
    being readable) then from the PCB editor (and schematic too I think) choose
    File->Export->Netlist.
    If you're trying to create your own netlist using a ULP then I'd suggest
    finding one in the ULP download area at CadSoft and then using that as a
    starting point.  It definitely can be done that way, I have done it myself
    though I don't remember the exact details off the top of my head.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specialising in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    James,
    Thanks for swift reply. Maybe I should have said that I've downloaded the
    netlist_protel_ulp, but it outputs pin names, and protel requires pin
    numbers... I want to modify the code so it works correctly.
    Maybe it's just a question of nomenclature...
    The information you are looking for is called the "pad name" in EAGLE.
    It should be possible to get the associated package from the schematic
    device, then access its pads and then their names.
    In many (most of the) cases the pad names are numerical. However, you
    should think about what to do when they are not, if Protel really needs
    numbers there...
    Tilmann
    Thanks Timann - I'll look for this in the help files.
    Tilman,
    The pad name only applies to boards, not schematics.
    It must be possible to obtain the pin number, because the in-built netlist
    exporter outputs those values as 'pad' in column 3...
    Can someone explain how to navigate the object hierarchy to get the pin
    numbers from the package relating to pinref of the the component in the net
    being processed here:
       SCH.nets(N) {
         numeric string Part[], Pin[];
         int cnt = 0, index[];
         N.pinrefs(P) {
           Part[cnt] = P.part.name;
           Pin[cnt] = P.pin.name;
           cnt++;
         if (cnt) {
            sort(cnt, index, Part, Pin, PinText);
            printf("%s\n","(");
            printf("%s\n",N.name);
            for (int i = 0; i < cnt; i++)
                printf("%s%s%s\n",Part[index[i]],"-",Pin[index[i]]);
            printf("%s\n",")");
    But it is referenced in the schematic as well (and is also displayed in
    the schematic as well, even if there's no board at all).
    I'm pretty sure it is possible, but I'm not used to writing ULPs...
    Perhaps you have a look at the following object hierarchy:
    - UL_SCHEMATIC has a loop member named "part", of type UL_PART
    - UL_PART has a loop member named "device", of type UL_DEVICE
    - UL_DEVICE has a loop member named "gates", of type UL_GATE
    - UL_GATE has a data member named "symbol", of type UL_SYMBOL
    - UL_SYMBOL has a loop member named "pins", of type UL_PIN
    - UL_PIN has a data member named "contacts", of type UL_CONTACT
    - UL_CONTACT has a data member named "pad", of type UL_PAD
    - UL_PAD has a data member named "name", of type string
    - UL_PIN also has a data member named "net", of type string,
      as well as a data member named "name", of type string
    By following this hierarchy with the appropriate loops and references,
    you get all pin/pad/net relations you need.
    Tilmann
    autodeskguest over 15 years ago in reply to autodeskguest
    Tilmann,
    Thanks for the help. This now works:
    if (schematic) schematic(SCH) {
       output(filesetext(SCH.name, ".NET")) {
       SCH.parts(P) {
         printf("%s\n","[");
         printf("%s\n",P.name);
         printf("%s\n",P.value);
         printf("\n\n\n%s\n","]");
       SCH.nets(N) {
         numeric string Part[], Pad[];
         N.pinrefs(P) {
           Pad[cnt] = P.pin.contact.name;
           cnt++;
         if (cnt) {
            sort(cnt, index, Part, Pad);
            printf("%s\n","(");
                printf("%s%s%s\n",Part[index[i]],"-",Pad[index[i]]);
            printf("%s\n",")");
    Thanks for the feedback. However, your "attachment" can't directly be
    accessed since that stupid web interface puts it UUencoded into the
    message body. If you want to share it, please provide it to CadSoft for
    their downloads webpage.
    Tilmann
