EAGLE User Support (English) Restriction of autorouter?
  • Replies 8 replies
  • Views 1669 views
I'm still pretty new to Eagle. I've made a few PCB's so far, and they've
turned out great, but I hadn't used the autoroute function at all until
now. I need some advice.
I've already routed a particular area of the board since it is a
measurement circuitry area. However, now that I want to route all of the
digital signals, is there a way to restrict the autorouter such that it
does not mess with my already routed measurement circuitry?
Brian
    Telemachus wrote on Mon, 15 February 2010 22:06
    James,
    Ok, thanks for the advice. Is there literature out there that goes over
    the "art of autorouting" in Eagle or anything?
    The best way is to sit down and play with it to get a feel for how it
    behaves and what the parameters do.  There is a useful section of the
    manual that explains all the parameters and their ranges.
    Quote:
    What I've ended up doing so far is to route the simple digital stuff,
    most of the analog measurement circuitry, and the power lines, but then
    divided my board into the parts that I've routed and those that haven't
    using the "restrict" layers. It seems to have worked: I ran the
    autorouter and it routed the complicated digital signals that would
    have
    taken me forever.
    That's a good way to use it.
    Quote:
    However, I guess I should clarify what I mean by "touching" the analog
    circuitry that I've already routed. For all intents and purposes, the
    circuitry that I've routed is perfect, but it wasn't to the autorouter
    because it looks to end traces smack-dab in the middle of SMD pads.
    Since I've got a mix of packages, it added all of these crazy angular
    traces, which I have to go back and delete now. Is there any way to
    stop
    the router from doing this?
    Yes and no.  You can use the command line to have the auto-router ignore
    certain signals or to only route certain signals.  See "help auto" for more
    info.  Note, wildcards can be used.
    But you really want to connect the final ends of those traces.  The
    ratsnest will report traces unrouted until they are all gone.  And you
    don't want to risk missing one that actually is not routed because you have
    100 that are almost routed.
    EAGLE 5 now has magnetic snap for the last segment to the center of the
    pads/smds so it's much nicer than it used to be.  So make use of that and
    route it right to the connection point.  If you finish a net EAGLE will
    beep at you so you know it's done.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Telemachus wrote on Tue, 16 February 2010 13:37
    Olin,
    Yes, that's well and good to look in the help, except that I don't find
    the help article on this particularly helpful. What is the purpose of
    specifying net classes? What are they used for?
    As Doug already mentioned, they are used by the DRC and auto-router.
    For more info about the auto-router see the online help for the "auto"
    command.  You can have it route a list of signals only.  But you can't give
    it a net class to complete, although I agree that could be useful.
    Also take a look at the auto-router section of the manual.  There is some
    useful info in there.  If you don't have a printed manual there is a copy
    in the /doc of the install directory.
    Cheers,
    James.
    The net classes allow you to specify different track sizes and spacings for
    different nets.
    This is used by DRC and the autorouter.
    "Brian Zuelke" <brian.zuelke@ndcpower.com> wrote in message
    news:hleoki$t9o$1@cheetah.cadsoft.de...
    Olin,
    Brian
    the digital signals, is there a way to restrict the autorouter such
    that it
    As James already said, the autorouter leaves alone anything already
    routed
    before you run it. You may want to put polygons in tRestrict, bRestrict,
    and vRestrict in specific places to keep the auto router from running new
    tracks thru your analog section.
    Quote:
    For all intents and purposes, the circuitry that I've routed is
    perfect, but it wasn't to the autorouter because it looks to end traces
    smack-dab in the middle of SMD pads. Since I've got a mix of packages,
    it added all of these crazy angular traces, which I have to go back and
    delete now. Is there any way to stop the router from doing this?
    Yes, don't leave dangling ends. Route your own traces to the middle of
    the
    pads and you won't have a problem. You should have had a bunch of
    airwires
    indicating that Eagle thought the connections weren't complete. If you
    got
    wierd angles, then you must have left the ends fairly far from the pad
    centers. Don't do that. As long as you get them close, the remaining
    route will all be within the pad and not change the resulting copper.
    It's
    really not that hard to do it right though, and that way Eagle knows for
    sure the connection is made.
    Quote:
    what do net classes have to do with the autorouter?
    HELP CLASS.
    Quote:
    Can these be used to route only certain classes of signals?
    I don't think so. The point is to tell the autorouter parameters for the
    tracks it creates.
    Olin,
    Brian
    that it
    As James already said, the autorouter leaves alone anything already routed
    Yes, don't leave dangling ends. Route your own traces to the middle of the
    pads and you won't have a problem. You should have had a bunch of airwires
    indicating that Eagle thought the connections weren't complete. If you got
    route will all be within the pad and not change the resulting copper. It's
    HELP CLASS.
    tracks it creates.
    the
    HELP CLASS.
    tracks it creates.
    On 2/15/2010 1:12 PM, James Morrison wrote:
    Telemachus wrote on Mon, 15 February 2010 13:04
    they've turned out great, but I hadn't used the autoroute function at
    all until
    that it
    Hello Brian,
    Of course, you could do your own experiments to determine this--just backup
    the files first.
    But to answer your question, the auto-router doesn't touch anything that
    was routed before it starts. So if you hand-route power and critical
    traces then it won't touch that stuff.
    This is generally good but sometimes if you pushed a critical route just a
    bit one way or the other you can fit one more trace through but the
    auto-router needs to add a via and things get way congested very
    quickly. So be careful where you put your critical routes. Your first
    pass of the
    auto-router may simple to figure out where congestion is going to occur and
    then go back to original design (copy of design before auto-router was run)
    and adjust critical traces accordingly.
    Cheers,
    James.
    James,
    One other thing: what do net classes have to do with the autorouter? Can
    Brian
    James,
    autorouter and it routed the complicated digital signals that would have
    taken me forever.
    traces, which I have to go back and delete now. Is there any way to stop
    Brian
    all until
    that it
    Hello Brian,
    the files first.
    pass of the
    Cheers,
    James.
    they've
    the
    Hello Brian,
    the files first.
    auto-router needs to add a via and things get way congested very quickly.
    So be careful where you put your critical routes.  Your first pass of the
    Cheers,
    James.
