EAGLE User Support (English) How to delete vias?
  • Views 1808 views
How to delete vias?
I'm running Eagle 4.13.  If I have a wire running on two layers, with a via
connecting the two traces, and I subsequently move one trace to the same
layer as the other, the (now superfluous) via remains in the layout.  If I
try to delete it with the delete tool, I get a warning that this operation
should be performed in the schematic (which has no vias).  I assume Eagle
thinks I'm trying to delete the wire.  Regardless, how can I delete the via?
I have several of these unnecessary vias, and one of them even has its
airwire still attached, running to the routed trace.  That may be an
unrelated problem, but I'd like to remove it, too.  Thanks.
    Telemachus wrote on Mon, 15 February 2010 22:08
    You have to use the "rip-up" button.
    No, you don't.  You want to use the RIPUP command somehow, but that
    certainly does not require using a particular button.  For me it would be
    SHIFT-F8, but that's how I have my keys assigned in the board editor.
    Typing "ripup" (I think just "rip" works too) is reliable.
    Use ripup tool
    Karl,
    You have to use the "rip-up" button. Careful not to rip-up the entire
    signal path, though. Only target the vias in question. I'm using v.5,
    but it should work. From what I understand, you use delete only when
    working with signal traces which don't have any correspondence in the
    schematic.
    Brian
