EAGLE User Support (English) Printing Multiple Images
  • Replies 11 replies
  • Subscribers 179 subscribers
  • Views 1619 views
autodeskguest over 15 years ago
Good day
I am still very much a beginner to Eagle but have managed to produce a
number of small board designs that I want to now use to etch the boards.  I
want to print the layouts onto clear film (HP Laser Jet 4L) and then etch
onto photosensitive boards.
Is there any way that I can print multiple images onto the film without
having to put the one film through the printer multiple times (which
doesn't work on my old HP 4L)? At the moment all I can do is to print one
image on one film which is wasteful and expensive.
Gareth
    Former Member over 15 years ago
    Open a new - empty - brd, save it & then go to the first brd, switch all
    layers on. Then: Group, Cut, open the new brd & paste. Do this process with
    all other brd. Back-forward-annotation is not active.
    But be careful: remember the restrictions for your version of eagle
    (80x100mm for the freeware).
    r
    autodeskguest over 15 years ago in reply to Former Member
    I cut out small part of the laser plastic film, then glue each one to a
    normal white paper(the same every time) and run it in my laser. After
    that i glue 3 pcs. plastic together for both top an bottom side(totally
    6 pcs.). It take some time, and you must me very accurate when glue all
    the pcs. together.
    I use a old cheap uv "facial sun" and put my uv pcb in middel of too
    pcs. glass. Light time in my case about 20 sec.
    I have made real complex double side smd prototyping that way.
    Hope it can help a little.
    all layers on. Then: Group, Cut, open the new brd & paste. Do this
    process with all other brd. Back-forward-annotation is not active.
    r
    Hi Guys
    Thanks for the feedback.
    To J.M. Rafetseder:- I have tried your suggestion and it works fine.  I
    found that I can also "group" and paste in the same board i.e. when I come
    to print the board layout I can also duplicate the board to fill the film.
    My boards are only small (60mm x 40mm) and are related to a model railway
    so I can fit several differant boards on one film.
    To Flemming :-  Am I correct in saying that the white paper acts as backing
    for the film pieces when they go through the printer? I am not sure how you
    get the layouts onto the film.
    Gareth
    Yes the white paper is only transport for the small plastic film.
    On 18-02-2010 13:26, Gareth wrote:
    Hi Guys
    film. My boards are only small (60mm x 40mm) and are related to a model
    railway
    Gareth
    Gareth wrote:
    Good day
    Yet another option might be to export to another format such as PNG,
    load it into a simple graphics program (MS-Paint?), do as many copies in
    there until the sheet size is full, then save that file and print from
    that program.
    Regards, Joerg
    "gmail" domain blocked because of excessive spam.
    Use another domain or send PM.
  • Johann.Glaser@gmx.at
    Johann.Glaser@gmx.at over 15 years ago
    Hi!
    Am Donnerstag, den 18.02.2010, 10:38 +0200 schrieb Gareth:
    I use the CAM processor to export to EPS files (which is a vector
    graphics format) and then write a small LaTeX file which has multiple
    \includegraphics[scale=1.0] to put multiple files on one
    sheet. This way I can add descriptive text, side lables, drill diameter
    legend, title, my phone number, ... on the sheet before I bring it to
    the guy who etches them for me.
    Alternatively you could use OpenOffice.org and insert the EPS files
    (which is extremely slow because it uses GhostScript in the background
    to display the EPS files, and does some senseless stuff). But be
    careful, the most important part is that the scale has to be exactly
    1.0, otherwise your PCB is scaled and no components will fit its
    footprints.
    Note that with Eagle 5.7 you have to set the paper size of the EPS file
    in the CAM processor to 100x100 inch, then the exported file has its
    bounding box exactly the size of the used area.
    I discourage you from using PNG (or any other pixel graphics format like
    GIF, BMP or even JPG) because this has a discrete resolution and will
    introduce "stair" effects for non-ortogonal lines. Increasing its
    resolution to some idiotically high value will not improve your case,
    because the printer will print gray shaded pixels which have
    unpredictable results with the photo resist. So, please stay in pure
    vector graphics all the time and let the rastering do the printer
    itself.
    Bye
      Hansi
    Johann Glaser wrote:
    Hi!
    footprints.
    itself.
    True. But in reality anything beyond 600dpi or on most older printers
    like Gareth's 300dpi will get smushed by the printer anyhow.
    I really liked HPGL but nowadays most programs no longer support that
    and plug-ins for HPGL don't always work right image
    Regards, Joerg
    Hi and again thanks for the relplies.
    I have "Grouped,cut and pasted" and it seems to have worked OK.  I did try
    previously to copy and paste into OOO draw but I was disapointed with the
    results, as has been pointed out my old HP 4L is does not give me high
    quality, so hence the request for help.
    I haven't tried copying the EPS files into OOO yet but will try it later.
    Again thanks to everyone for the help.
    Gareth
    Gareth, you might want to play around with the settings for that
    printer. For example some of the RET settings might not be so suitable
    for this job. Printer memory size may be another issue. I upped my old
    5L to 5MB, thanks to a friendly participant in a European NG.
    So far my attempts of importing EPS into OpenOffice were not all that
    successful.
    Regards, Joerg
    autodeskguest over 15 years ago in reply to autodeskguest
    On Fri, 19 Feb 2010, Gareth wrote to us saying :
    I've done this sort of thing, again with an HP4, by printing to a bunch
    of files and merging them with some postscript manipulators. Actually I
    hacked up a bit of Python to combine them. This gives good enough
    results because it doesn't munge the data so the scaling remains intact,
    but my hacked-up script isn't totally PS-compliant and breaks with
    output from the wrong programs (possibly even Eagle 5, as I wrote them
    for 4.15).
    Coincidentally that was also for model railway stuff
    (http://lintrain.sourceforge.net)
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
