EAGLE User Support (English) How to re-use PC Board outilnes
  • Views 523 views
CasaDelGato
CasaDelGato over 16 years ago
I've made up some packages that are just the PC Board outline that is
required to use certain boxes.
It's just an outline of the board (Dimension layer) with some holes.
I've found that if I try placing the Package, all the Dimension lines
get converted to Place lines.
If I try Copying the package to the clipboard, then pasting it onto my
board, all the lines and holes come in - but once placed, i can't
select any of the lines or holes at all.  I can delete the lines but
not the holes.
How am I supposed to be dealing with using pre-built specified board
outlines?
  • CasaDelGato
    CasaDelGato over 10 years ago in reply to autodeskguest
    You do realize that you are responding to questions that were asked 6 years ago?
    don't copy, add.
  • CasaDelGato
    On Fri, 19 Feb 2010 16:26:31 -0500, Olin Lathrop <eagle@embedinc.com>
    wrote:
    John Lussmyer wrote on Fri, 19 February 2010 11:35
    outlines?
    Make them packages, not devices.  You can add just a package from a library
    to your board.  I have outlines for several boxes with maximum allowed
    board size and mounting holes just like you mention.  They work fine.  The
    dimension wires stay in the dimension layer.
    Well, I'll try that again.  I actually did create them as Packages,
    but got weird results when I dragged them onto the board.
    I've found that doing copy-paste of the package from the library
    editor to the board is REALLY weird.  It copies it in, but then you
    can't edit it at all.  Once it's placed, it's permanently there.
    outlines?
