EAGLE User Support (English) Requesting known good CAM job for 4 layer board
  • Subscribers 186 subscribers
  • Views 418 views
I'm looking for a CAM job file that is verified working with a board house
for 4 layers, so nothing mirrored that shouldn't be, etc etc.
I've found plenty of files that may or may not work, I need something that
is known to work.
Baldur
    Baldur Gislason wrote on Mon, 01 March 2010 15:34
    house
    that
    is known to work.
    The particulars depend on your board, like whether you used a layer as a
    full plane, whether there are parts on the bottom, etc.  My generic 4 layer
    CAM job (attached) is a good place to start.  If you aren't using layer 3
    as a plane and the others as signal layers, you will have to adjust that.
    See the description for details.
