EAGLE User Support (English) Open file from command line in linux
  • Replies 7 replies
  • Subscribers 178 subscribers
  • Views 1609 views
autodeskguest over 15 years ago
Hi.
I'd like to get a list of what command line parameters
eagle can be run with on linux.
I'm looking for a way to open a (schematic) file from the
command line (so that i can create a .desktop file to
open eagle files).
Anybody? Thanks.
  • dukepro
    dukepro over 15 years ago
    On 03/03/2010 11:49 AM, Thomas Lundgaard wrote:
    Hi.
    open eagle files).
    Not sure about schematics specifically, but
        shell> eagle eagle.epf
    works at the project level.  I have also added a file association in
    Konqueror to associate .epf files with eagle.  So a single-click in
    Konqueror (or any other file browser) will launch eagle.
    Enjoy,
        - Chuck
    association in
    single-click in
    eagle.
    That doesn't works for schematics files. If I run
         sheel> eagle document.sch
    eagle will start and first complain that the directory
    document.sch doesn't exists (oviously, it's a file) and
    then sets the library directory in Options >
    Directories to /home/user/path/to/document.sch. I
    really consider this weird behaviour, don't know if
    it's a bug?
    I'm using eagle 5.7.0 on Archlinux.
    Cheers..
  • dukepro
    association in
    single-click in
    eagle.
    it's a bug?
    Good morning,
    That is odd behavior.  I did a little experimenting this morning and
    found that I could supply eagle with any .sch .epf .brd or .lbr, and it
    starts without complaint.  The elements in Options->Directories did not
    change.
    Furthermore, I can:
        shell> eagle 513941.sch 513951.brd
    and I get a control panel, a schematic editor, and a layout editor windows.
    I, too, am using 5.7.0.  I'm running opensuse 11.1, KDE4 window manager.
    "uname -a" shows
    Linux lightning 2.6.27.45-0.1-default #1 SMP 2010-02-22 16:49:47 +0100
    x86_64 x86_64 x86_64 GNU/Linux
    This is a fairly new kernel - I installed it two days ago, but I doubt
    that has anything to do with the behavior exhibited by your installation.
    I'm not sure if this provides any useful information.
    Enjoy,
        - Chuck
    Thomas Lundgaard wrote on Wed, 03 March 2010 18:00
    I just tried it on Windows 2000 and it seems to work correctly.  Of course
    then it doesn't open Eagle thru the Windows menu shortcut, so it picks a
    arbitrary window size and position for the control panel whereas it's
    opened maximized when I run it from the menu or my special CTRL-ALT-C
    hotkey for Eagle.
    Personally I run eagle with by using the aforementioned hot key, then use
    the TAB, arrows, and ENTER keys to navigate thru the control panel and open
    the schematic, library, or board that I want to work with.
    autodeskguest over 15 years ago in reply to dukepro
    Hi All,
    Thanks for your help so far.
    I found the issue now. I'm running archlinux and for some reason the eagle
    package in AUR installs an eagle executable in both /usr/bin/eagle and
    /opt/eagle-5.7.0/bin/eagle. If i run
    /usr/bin/eagle file.sch
    it does the aforementioned weired behaviour, but if i run:
    /opt/eagle-5.7.0/bin/eagle file.sch
    it opens the schematic as it's supposed to.
    I guess it's some sort of packaging issue, so I'll post it in the AUR
    comments.
    Cheers, Thomas
    On Mon, 8 Mar 2010, Thomas Lundgaard wrote to us saying :
    comments.
    Check exactly what /usr/bin/eagle is. On my Gentoo box with an official
    CadSoft CD install of 4.15 there are also two executable paths. However,
    /usr/bin/eagle is merely a symbolic link to /opt/eagle/bin/eagle. I
    don't have the box with v5 running right now to see if that's the same.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    eagle
    comments.
    If I remember correctly, in Arch, it's a script that sets up some
    environment variables and creates your .eagle directory if it doesn't
    exist.  It probably doesn't pass its own command-line parameters to the
    final executable.
    -Dave
