EAGLE User Support (English) Help with UPL "if plur OR "
  • Subscribers 177 subscribers
  • Views 529 views
autodeskguest over 15 years ago
I am modifiying an ULP that adapts all drill sizes to Olimex ones but
I want to check if the drill size is already and olimex standard.
So I want to check the value of "rval" against the standard values, so
have made that line ( formatting has been los a little )
but i get an error when running the ULP, have I made something wrong in
the
if.....
line
code fragment starts-------
real rval=isdrill// first we check if the drill value is an Olimex
standard, if so we do not modify it
if (rval!=3.3 || rval!=2.1 || rval!=1.5 || rval!=1.3 || rval!=1.1 ||
rval!=1.0 || rval!=0.9 || rval!=0.7) {
rval = round((isdrill+round_offset) * 10.0) / 10.0; // round value
code fragment end-------
Thanks in advance
    the
    if.....
    line
    Thanks in advance
    Since the order of || and != could be confused it may be that adding
    grouping as
    if ((rval != #.#) || (...
    may help
    I have not looked for ULP documentation to see if != are done before ||
    are at the same time.
    Paul R.
    the
    if.....
    line
    Thanks in advance
    There will always be one of those OR conditionings true so your  IF
    statement always evaluates as true and so you will always do the rval =
    round etc.
    Warren
    maybe wrote on Sat, 20 March 2010 07:20
    There are many board houses out there.  Why waste time with the only one
    that can't multiply by 25.4, with a uppity attitude on top of that?
    Around 8 years ago I thought I'd give Olimex a try on some prototype
    boards.  I put together the same package of files that plenty of other
    board houses would have had no problem with.  Instead of boards, I got a
    rather rude and terse email from Svetan about how the hole diameters
    weren't metric, with the attitude that I was a jerk for wasting their time
    with that.  No, I wasn't going to make one set of files for Olimex and one
    for everyone else.  I found another board house that charged the same
    (possibly even less if I recall correctly) and used the files as they were
    without problem.  I never even mentioned Olimex to the customer.  This went
    on to become a significant volume product.  I don't know where the customer
    gets their boards today, but I know they started out with the same place I
    used to get the prototype boards made.  They also used them for assembly
    work later.
    I don't know how much business Olimex has lost with their arrogant attitude
    and the fact that their computers can't multiply by 25.4, but I know of
    some for sure.
    "Olin Lathrop" <eagle@embedinc.com> wrote in message
    news:ho3ij6$fc8$1@cheetah.cadsoft.de...
    that can't multiply by 25.4....
    Hey Olin not need to repeatedly slag them off. Taking your business
    elsewhere is the correct course of action.
    I have always assumed their restrictions were in place to streamline their
    process and therefore offer cheaper prototype boards. I would imagine to
    convert line thicknesses and drill sizes to make them suitable for their
    process would also be simple and automatic post process but it gives them an
    opportunity at add a couple of dollars to the bill. That's their business
    model.
    Many thanks for your tips but after many many trials have found the the
    problem was not in that line, it was wrong of course, but in a previous
    one.
    I will keep onto learning ULP as this is my firs attempt to it.
    Many Thanks Again Octavio
    In article <200320101220123048%maybe@maybe.com>, maybe
    the
    if.....
    line
    Thanks in advance
    Greg Erskine wrote on Sat, 20 March 2010 18:59
    I guess that means you didn't get a rude email from Svetan for the horrible
    crime of sending them files that didn't have metric hole diameters.
    Quote:
    Taking your business elsewhere is the correct course of action.
    So is warning others.
