EAGLE User Support (English) COPY & PASTE ( or CUT & PASTE ) betwe en Layers?
  • Subscribers 177 subscribers
  • Views 475 views
autodeskguest over 15 years ago
In the LIBRARY EDITOR - EDIT PACKAGE WINDOW, I am having trouble trying to
"COPY & PASTE" or better "CUT & PASTE" between layers!
The cut and paste buttons are totally unfriendly!
Its annoying enough as it is, that EAGLE CAD does not always show the
current ACTIVE LAYER, so often I start drawing in the wrong layer, and many
layers are coloured the same.
So what is the easiest way to copy from ONE LAYER (or better to CUT) and
then paste that onto a new layer
So far my attempts alway copy to the same layer! even though I turn OFF
that layer.
Thanks!!
Dave M
    davem wrote on Tue, 23 March 2010 07:12
    This is more of a rant than a question, so I'm not going to respond
    directly.
    However, keep in mind Eagle uses unfortunate command names for a few
    things.  CUT actually does a COPY, and COPY never seems to do what you
    want.  WIRE is used to draw lines, except when those lines represent wires,
    then you use NET.
    autodeskguest over 15 years ago in reply to autodeskguest
    Hi Olin,
    NO, its a question,
    How do you copy & paste between layers?
    Again,
    Dave M
    Am 23.03.2010 12:12, schrieb davem:
    What do you think about CHANGING a Layer image
    Normally eagle shows the active layer in the parameter menu.
    Don't COPY just CHANGE
    that layer.
    Thanks!!
    Maybe you should have a look into the manual image
    Dave M
    Regards Stefan
    Hi, Stephan,
    So you are saying to change, I need to "CHANGE" a group of drawing objects,
    i.e lines etc from one layer to another, nothing seems to work, when you
    select group, only one of the drawing items( objects) moves, not the
    objects selected in the group!
    This is so annoying!
    DaveM
    On 3/23/2010 4:18 PM, davem wrote:
    Hi, Stephan,
    DaveM
    select GROUP and gather your objects.
    select CHANGE:LAYER
    /Right Click / one of the objects in the group to apply the command to
    the whole group - left click is to an individual object.
    EAGLE does everything differently, you need to read and follow the
    tutorial to get familiar with it, or you will be very annoyed until you do.
    Hi Gary,
    Thanks for the reply, I shall try that!
    Dave M
