EAGLE User Support (English) Freeware or cheap IDF Viewer
  • Views 2631 views
Ok, I'm successfully making my IDF files.  However, I'd like to view
them to make sure that they look reasonable before handing them off to a
mechanical designer.
Anyone know if there is a freeware/opensource/cheap IDF viewer out
there?  I use the eDrawings viewer from SolidWorks to view/check 3D CAD
files for mechanical enclosures and racks and it works well, it just
doesn't support opening an IDF file.  I don't need to edit/modify the
IDF files I am producing, I'd just like a sanity check before handing
them off to someone else.
-Michael
    Thierry Pottier wrote:
    I use ALIBRE a cheap but not free CAD.
    I can try your file and make a PDF of drawing.
    I have try before to use the uld but not succes.
    Now I use PovRay. Nice to make documentation.
    Thierry
    Thierry,
    It seems to me that Eagle3D and perhaps PovRay are used to make a human
    viewable 3D image (rendered to 2D) for perhaps documentation purposes.
    What I am looking for is a 3D model to be imported into a 3D CAD program
    (SolidWorks in this case) so that my mechanical designer can design the
    enclosure that this PCB goes into (checking for mechanical interference
    for instance).  Do I have this right, or can Eagle3D or PovRay also make
    a mechanical model that can be used in a 3D CAD environment?
    -Michael
  • tpelectronics
    tpelectronics over 16 years ago
    Thierry
    "Michael Sansom" <mssansom@hotmail.com> skrev i melding
    news:hpvdaa$n2a$1@cheetah.cadsoft.de...
    -Michael
    Michael,
    It would be really great if you could write up a faq/howto on the process
    for generating IDF files from Eagle....now that all the steps are fresh
    in your memory!    Eagle3D is great for making presentations but as you
    found out..the mechanical engineers don't have much use for it!
    Perhaps you could write up the steps, the software packages used (other
    than Eagle), and upload a guide to the cadsoft website.
    Nice work..!
    Jim
    I will do so, but I do want to check my output before putting up a howto
    (since I am not 100% sure that I did it right till I can look at he
    results).  It's really fairly easy, the guy that wrote the ulp obviously
    did all the heavy lifting.
    -Michael
    a mechanical designer.
    CAD files for mechanical enclosures and racks and it works well, it
    just doesn't support opening an IDF file.  I don't need to edit/modify
    the IDF files I am producing, I'd just like a sanity check before
    handing them off to someone else.
    -Michael
    Michael,
    process for generating IDF files from Eagle....now that all the steps
    are fresh in your memory!    Eagle3D is great for making presentations
    but as you found out..the mechanical engineers don't have much use for
    it!    Perhaps you could write up the steps, the software packages used
    (other than Eagle), and upload a guide to the cadsoft website.
    Nice work..!
    Jim
    -Michael
    -Michael
    Michael,
    Nice work..!
    Jim
