EAGLE User Support (English) Paper sizes?
  • Subscribers 177 subscribers
  • Views 321 views
Paper sizes?
autodeskguest over 15 years ago
I've just bought some very expensive paper to use with Eagle, so I don't
want to use a whole A4 sheet each time; ideally I will cut it into four to
give A6. My printer can easily print A6, but it isn't in the list in the
Eagle Print dialog.
Can I add A6 paper size, or perhaps a custom size?
Nigel
    Later discovered that if I go to Print Setup, then the Printer Properties
    then I can select this paper size when I get back to the Eagle dialog.
    Eagle forgets all the settings if you do a second print, but I can live
    with that.
    Nigel
    nigelmercier wrote on Thu, 15 April 2010 08:25
    don't want to use a whole A4 sheet each time;
    Get some cheap paper and don't worry about it.  I use ordinary 8 1/2 x 11
    inch copier paper in my inkjet printer.  That's about as cheap as it gets,
    and it works fine.
